996 GT2/GT3 Forum 1999-2005
Does anyone here use PCCB on track regularly?
Old 10-18-2008, 07:28 PM
Backmarker
Backmarker's Avatar
Default Does anyone here use PCCB on track regularly?
Hi,
I'm a new GT3 owner and my car has PCCB
I am a regular track guy, I do 10-15 events/year
What I want to know is- does anyone here run PCCB gen I or II on track regularly?
If so, what has your experience been and how are you running them reliably (eg pads, ducts, maintennce, etc)
Please *don't* reply and tell me about iron rotors, or how you heard/read they fail, I know all that, I read all the old threads...
I just want to create a thread of folks who are running PCCB on track
Old 10-18-2008, 07:51 PM
GT3 Chuck
GT3 Chuck's Avatar
ok, I'm one but they are gen II's...have 10k miles and about 20 track days (3 seasons), with quite a few in high heat...no problems...rotors look good with the fronts now starting to show some minor cracks around some of the holes...I started tracking in a momentum car and I'm not hard on the brakes like a lot of other GT3 drovers...change pads (stock pccb pads when necessary - less than 1/2 material left) and fluid often (twice a season).....if you are going to run that many events, and if your driving style is hard on brakes then you should wear out the pccb's and switch to iron
Old 10-18-2008, 08:01 PM
AllanJ
AllanJ's Avatar
I run gen 1 PCCB on the rear of my car. 18 track days so far and they are fine, mostly on a track that's hard on brakes. I ran a couple track days on the front PCCB and saw a couple cracks around the holes so I swapped for iron on the front because of what I read in the old threads. I'm running stock pads on the rear.
Cheers,
Old 10-19-2008, 12:53 PM
Backmarker
Backmarker's Avatar
Thanks guys. Anyone else?
Old 10-19-2008, 01:26 PM
GT3 Chuck
GT3 Chuck's Avatar
I think more of the 997 guys run pccb's so you might get more action in the 997 section...all 996's had Gen I's and most of the track guys switched them out rather than replace them...mine was a late 2005 and the dealer had installed Gen II's...when mine are gone I will probably swap them out due to expense of new rotors
Old 10-19-2008, 05:58 PM
997gt3north
997gt3north's Avatar
- i'm a 997gt3 with pccbs
- about 35 trackdays with the car
- the first 25 were run with the stock pads - the last with the green p50 motorsport pads
- it is a great setup but nothing last forever when tracking
- i figure i will get another 20 days out of them so maybe 50 in total
- i know a guy 997 with a C2S that is fast and his lasted him 30 events (thats what he told me and i never saw them when he replaced then with custom irons using his stock hats
- i guess if they last lets say 50 events you have to ask how many sets of irons you would go through (maybe 5 plus labor) and then weigh the cost benefit of the two systems
Old 10-19-2008, 07:19 PM
roberga
roberga's Avatar
My car has at least 150 days from tracks in the Pacific Northwest VIR, the Glen, T-hill and a few others. THe rears are orginal the fronts are GEN II. The total miles are 58,000 and the front rotors have about 45 track days on them. First 20 miles were the black P-40 the rest Motorsport greens. The greens have P-50 front and the rears are still P-40 but the pad is thicker than the blacks.
I love what I have. If the car had irons I am sure I would be happy but the PCCB has worked for me.
Old 10-19-2008, 10:00 PM
Mr Michael B
Mr Michael B's Avatar
Gen 1 user, no problems. But I too am easy on brakes (spec miata racer)
Old 10-20-2008, 01:47 AM
Backmarker
Backmarker's Avatar
Thanks for the info. I don't know your tracks, are you a doing much braking from 140-150 MPH down to much lower speeds?
At my favorite track I have 4 braking zones from 130-140 down to 60, 85, 70 and 60 MPH
Old 10-20-2008, 10:51 AM
997gt3north
Mosport
- 3rd fastest track in the world
- 2 very hard braking zones (150 to 80, 130 to 40)
Watkins Glen
- similar to Mosport but harder on brakes for sure but still not brutal
- bus stop (150 to 70), outer loop (120 to 70), into the toe (115 to 50), the heal ( 125 to 45), front straight (130 to 70)
VIR
- another fast one but with two huge 150 to 35 decels
Tremblant
- mini Watkins glen i call it
Those are my main tracks - Road Atlanta is on my wish list
Paul
Old 10-20-2008, 12:35 PM
roberga
roberga's Avatar
My local:
Seattle
t -2 : 165mph > 70mph
t-3: 130 > 35
t-5: 120 > 65
t-8: 115 > 55
Portland:
t-1: 155 > 40
t-4: 100 > 50
t-7: 80 > 30
t-10: 150 > 80
Old 10-20-2008, 12:51 PM
Backmarker
Backmarker's Avatar
Sounds similar to what I am seeing at THill and Laguna
Are you guys running cup car cooling ducts up front?
Old 10-24-2008, 11:56 PM
Backmarker
Backmarker's Avatar
I decided to run the green p50 pads on the pccb for the rest of the year
I'll keep this thread posted as to how it holds up
Old 10-25-2008, 12:18 AM
roberga
roberga's Avatar
yes
never go below 50% pad material and keep the holes clear
Old 10-26-2008, 05:15 AM
JDSStudios
JDSStudios's Avatar
Mosport
Paul
Paul
which ones are the fastest?
Quick Reply: Does anyone here use PCCB on track regularly?
