Airbag cutoff jumper??
#61
At this point I don't think we care what the Ohm is (seen everything from 2 ohm to 2000 Ohm ). For all we know a little Gnome could be sitting behind the wheel turning it off for you at the track
As long as it does what is needed, then great job!
#63
You'll have to remove your wheel to get to the plug like the one Turbocup posted. Either you will need to use this solution or just remove the airbag. The only problem is that you will get the airbag light by just removing it.
Having a DD car is a compromise so you need to figure out what you are willing to compromise. My compromise was to make it a dedicated 100% track car and remove the wheel and airbag and replace with a cup wheel.
#64
If you want your air bag out of the car, you do the same thing-- it matters not what kind of wheel you use. When I first tested it, I had no wheel in the car, just the jumper.
