Fabspeed Mufflers - Power loss/gain?
Looking for a nicer sound without Hp/Torque loss. I'm focussed on Fabspeed here because a highly credible and unbiased R'lister has recommended them. What I'm hoping to find is someone who has a before and after dyno test to independendly (not the manufacturer) confirm if there are gains/losses from swapping the stock mufflers with Fabspeed mufflers (stock cats/headers.) Anybody done that?
Thanks!
Thanks!
Fabspeed cat bypass, fabspeed mufflers & evo intake... no change in peak HP on dyno, +10hp upper midrange. Definitely did increase total HP area (area under curve) but not by much. There is not much you can do to add HP to these cars. Look at what the X51 has to gain 25hp... heads, cams, ECU, headers and more!
Great input Ed. I'm not hot to gain any HP... Just don't want to lose any.
May be a dumb question, but do the stock cats have significant flow restriction...as compared to, say, the stock mufflers? Never seen inside a cat, so not sure what is going on there...
I'll check out the Evo intake as well.
Thanks very much.
Thanks very much.
GT3 player par excellence
Thanks very much.
Thanks very much.
I ran sport mufflers, catbypass and muffler bypass pipes.
I noticed better response with the sport mufflers, and even better with the muffler bypass pipes, just my perception. The Fabspeed mufflers remove 26 lbs from the back, and the muffler bypass pipes 45 lbs.
With the cat bypass pipes, I used the stock exhaust, I liked the sound a lot. No noticeable improvement in performance, but I guess the stock mufflers were a bottle neck. No CEL with this setup.
This is great input and very much appreciated.
Weight loss and nice sound is what I'm after. 26 lbs out of the rear end is a great psychological improvement, and I'll be reminded of it every time i'm WOT. The car out-performs me in a big way, so I just don't want to compromise the power by installing a nice sounding/lighter weight muffler system.
I'm getting the impression that I don'thave to worry about power loss.
Hey Drew,
Local tracks won't do with MBP, so that's out of the question for me. Need to build my own track and to hell with the neighbors!! Do you keep the cats when you do a MBP?
Anyway, great avatar...is that Cobalt Blue? You might have noticed I have a thing for that color...couldn't find a car that color, so did the wheels...
Cheers...
Cheers...
Hey Drew,
Cheers...
Cheers...
Hey Drew,
Cheers...
Cheers...
SP will meatball you too. you should see the crazy setups i've seen. it all depends if the club holding the event is paying for low dB or high dB.
Interesting how the tracks dB level might vary. That is a surprise to me.
Anyway, I'm not into big sound (so not interested in the MBP set-up), just what I consider to be good sound, as well as weight loss. Very subjective, I know.
Pretty confident now that Fabspeed Mufflers won't cause any loss in power, so I'm keen to try them out.
Really appreciate the input.
