Fabspeed Mufflers - Power loss/gain?
Love my Cargraphic mufflers. Two others local have heard them, and bought their own. Great sound, and the aforementioned weight savings, too. No dyno, but Cargraphic claims 5 hp gain.
HA!!!! i was meatballed at TH with the bypass pipes. the crew at TH is just very inconsistent. it happened at an NCRC event.
SP will meatball you too. you should see the crazy setups i've seen. it all depends if the club holding the event is paying for low dB or high dB.
Which event meatballed you at SP? Thanks for the heads up Carlos
That's the thing. Loud is cool (sort of), but I have no time or patience for spending 4 hours before and after an event to change mufflers. I prefer to wash, maybe wax, check brakes and tires, a nut here and there and its done. Considering what you get out of them, it is really amazing how little effort these cars take if you leave them stock.
GT3 player par excellence
i was talking cat back.
you have included headers.
also, even with header, they are bumping from 380hp to 410? they have to do something else. header alone wont do it, trust me.
sorry, i am blind. didn't see the "map" part.
sure, advance timing, add fuel, increase air, more exhaust out... there you have 30hp, but that is NOT "exhaust system" that most ppl are talking about.
i wasn't meatballed at SP but others were. it all depends if it is a 92dB, 98dB, 102dB day. just make sure you only go to the 98 and 102 days
technically, all cars at TH need to have mufflers. did you ever notice the sign just under the control tower?
Don't think I saw the sign. Good to know though.
But if you want to run Laguna.....well, this is why I won't mess with the stock exhaust for little to no performance gain.
