Toe links/ control arms
#31
Martin, feel free to PM me anytime. I am sure Matt would be more than happy to answer any questions as well. I know he is new to the GT2 but he is NOT new to the track and his knowledge is pretty deep as well.
I'd probably ping him at least to get clarification on the toe arms.
#35
#36
Make an appt with a race shop to install them and then align and corner balance the car.
#41
If you are asking that question, then you really need to leave that work to the professionals. Adjusting a toe arm is not just the only thing that is done, but rather one piece of the ENTIRE suspension system and there is an order of what adjustments to make and in what order to properly setup a car. Screw up the toe setting and you could go for a scary ride.
Dell, after adding all of these components , do you need a new alignment/corner weight and balancing? I just got mine done :/
#42
Makes perfect sense, can't believe I asked such a stupid question lol... Sucks that I just got my whole suspension reworked too, ah well..
#45
I agree with you. When I do something with the suspension I always realige my car but I have no chnce to make balance. Only toe, camber, caster etc. I changed height this time and thatswhy I send my car to Germany for rebalance.
question is:
1. If I exchange toe links (adjustable/ no adjustable) have I got to make corner balance again or just geo without balancing?
2. maybe no adjustable are easier to use?
3, as for adjustable to bump, Dell do you always adjust toe link along with each change in your moton's bump?
question is:
