Rs parts
The RS uprights are made of magnesium. They're hollow pieces (very light), but also stiffer ( don't flex that much). Great upgrade for both front and rear. If you want to reduce rear bump steer.
As I understand, the RS rear subframes are required if using the rear RS uprights. I was told this by the vendor. However, I saw a car running stock rear subframes with RS uprights.
As i understand and as i have found out after some reading you think that there isn't worth the uppgrade unless i want the weight diffrent, i have done everything els to correct the the bumpssteer isuses
