Anybody running the Performance Friction Direct Drive 2 piece rotors???
The 6 is sold and the 7 deal is tentative now--they are not selling out from under me but I am not happy with the difference between what I thought was our agreement and what they thought it was.
Originally Posted by LVDell
Randy, you lazy boy! What, like you have other things going on in your life besides the car? It's not like you are spending your time at the track lately ![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Dell, your days are numbered, homeBOY!
POOF! will be the sound of your track time in about 2.5 months.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Originally Posted by mooty
assumption could be true.
but do realize that your hat will wear, i be surprised to see hats in good shape after three disk changes. also, unless you torque each nubbin to spec when you you replace the disk,....
I didn't think about the attachment hardware cost along with the disc. Good point.
In the end, I'm not happy with how fast the stock/cup rotors wear out. Everybody seem to lose them to cracking that is secondary to the holes. If Porsche made a solid rotor I probably wouldn't be using aftermarket ones. Even if I go back to stock rotors someday, I'll probably stick with the PFC pads.
They just feel stronger and more linear on the track than the Pagids.
YMMV.
Jim, the hardware and disc is a complete kit when you have replacement. The kit runs $300 a side. With the cup rotors running $300 a side, if we get just a 2 for 1 (meaning 2 cup rotors used in the time it would take to wear out 1 PF) then we already saved $200 on the initial investment.
Now some quick math for mooty et al that think there is no $AVINGS.....
If 2 for 1 ($ave $200):
PF $1K for first set
Cup $600x2 sets=$1200
Second 2 for 1 ($ave $800 total):
PF $600 (now $1600 total)
Cup $600x2 (now $2400 total)
At worst a 3:2 ratio (3cup to 2 PF) you still save $200!!!
PF $1600
Cup $1800
PF $1600
Cup $1800
GT3 player par excellence
Originally Posted by Jim H.
I did ask PF about when the hat would need replacement and when the disc was out of spec. I didn't really get a solid answer on either but they implied the hat wasn't a wear item. More to follow when I get close to changing out my discs.
YMMV.
YMMV.
brembo also told me hats aren't wear items.... well, the holes on the hat (where nubbins go) got bigger... so i decided not to use them. for those more brave, i suppose you can use them forever.
and yes, oem (cup rotor) included crack big time. i get 1000 miles out of them on avg. by then, i have 4-5 cracks connecting
PF $1600
Cup $1800
PF $1600
Cup $1800
i didn't mean to say NO SAVINGS.
just that it i sn't as big.
also, i ran brembo not PF (dont know much about PF), and the initial set (disk and hat) was about $1000/side. so i was and still bitter about my minimal savings.
Thanks for the info Dell. I didn't know the details on replacement kits but that's some good news. Now we'll just have to see how long these rotors last.
One more minor savings I just thought of is the caliper bolts ($20.00) that should be replaced everytime the caliper is R&R. Small but notable.
dell you got me.
No need to replace the bolts EVERY time. Cheap preventative item but still, not needed.!
I have read posts where people have reused them without catastrophe so perhaps this is just an intellectual argument.
I think NJ experienced some kind of issue with caliper bolts that ruined his uprights. I might be wrong on my recall but if so...
Cheers.
On my street 911 I do not replace the bolts every time since it doesn't see heavy braking. But the GT3 I will on the next go round. I reused the bolts this last time. I guess now that I am really starting to use the brakes as they were meant to I should prob change out the bolts everytime.
well if any interest. I had PCCB and change to PF and 01. I had this set up for about a year know and more than 30 weekends with this set up. I am on my second set of pads and Rotors are about to go.
The braking is way better than the PCCB"s More predictable and once you have given them a good heat cycle they are very predictable.
I have to change to Castrol CRF since all the other Brake fluids will go bad after 1 weekend. CRF and PFC and 01 work just perfect.
If more feed back needed PM and we can talk.
Cost was about 1300 for front rotors, rear pads and front pads ( for the rear I am running a custon set of Arlen Racing rotors that are 2 pice same size as the factory PCCB
I know getting litewieght is a good thing and 2 piece seems to be the sol'n but man I don't need weight taken off the front butmore so with the back. I relocated my battery down to the front just to give more balance in the front. mike
Note that, in my experience, that $1,300 does not include hats for the initial setup, which are another $4-500.
Originally Posted by nmex
...Cost was about 1300 for front rotors, rear pads and front pads ( for the rear I am running a custon set of Arlen Racing rotors that are 2 pice same size as the factory PCCB
From what I have got in research the FULL 2-piece set is $500 a side and $300 a side if you are just getting rotors/hardware replacements a side. Pads are $400 up front and $200 in rear. So $1600 to start or $1200 if you have the hats.
I'll make a decision within the week and keep y'all posted. My next big event is a 3-day at VIR in 4 weeks so I will have something in place by then so I can get a full write-up at after.
Thanks again for everybody's input!
nmex....I'll hit you up in PM
