Important Brake Lessons Learned
First off, I had OEM rotors on my car and was looking at them hard to see if I could get another weekend out of them. They looked okay according to all of the general wisdom, but, I had a 3 day track weekend coming up and didn't want to chance it. As I was changing them out, I was lamenting that they were probably still good but then, ahah!. turns out they weren't
...(see first two pics)
Lesson learned. Gotta look close. I see over 155mph on the back stretch at Mid-Ohio and I hate to think I was almost doing that on brakes that were unquestionably gone.
Well, good time to upgrade brakes anyways. PMNA was out of stock of the cup rotors at the time, so I plunged into a set of Direct Drive PFC floating rotors
Thanks to info on this site and on renntech, the install went easy and I ended up with this...
(third pic)
So far so good, and in the process I found a small craftsman bar clamp that made spreading the pads SUPER EASY and safe on the calipers. Life was good.
After finishing up both fronts and installing my one weekend old RS-19s, I was getting ready to go bed things in and happened to notice something. The pads didn't fit right and were riding up on the inner lip of the rotor. Worse, the backing plate of the pads was near the plane of the studs that held the hat to the rotor!
Like this...(fourth and fifth pics)
Time to get on the phone and see what's up with this Turns out that PFC direct drive rotors are only supposed to be used with PFC pads. The swept area of the PFC rotors is a few millimeters smaller than the OEM rotors. This was supposed to be known by the folks who sold me the rotors but alas, human error won out. Ouch. It would have been easy to take off and bed in the new rotors and it may have worked okay...for awhile, but then again it may have been disastrous right off the bat. Eventually, something bad would've happened I'm sure. Interestingly, things went together very easy and the rotor spun freely with no binding with hand spinning. It wasn't blatantly obvious that something was wrong.
Oh well, no harm no foul. Performance Friction was very receptive to my findings and labeling suggestions. They made things right on their end. I am impressed with their products and with their support. If their braking components work as good as they say, I'll stick with them no problem. Track report to follow...
Oh, and I managed to get some cup rotors shipped to me rather unexpectedly in the process. They are available if someone else needs them (see other post).
Summary lessons learned.
1. The cracks that take the OEM rotors out of spec can be very subtle, so look carefully.
2. Check and double check safety equipment (brakes, harnesses, etc). In this particular case, a good axiom to live by (pun itended).
3. Be careful about mixing different manufacturers equipment (PFC and Pagid in this case).
Hope the pics lined up right and show good detail (shoot they got added at the end).
Take care.
Good pickup.
Some of your cracks look rather long... on the order of maybe 7mm. Runout looks ok, but I would've tossed that set probably before that one crack reached the edge.
No way would I chance those Pagids on the floating setup with such small clearance.
The new rotors look nice!
Cheers
Good luck with the discs? I just got my replacement set of floating AP front rotors.
$9.95 at any sears store.
From the reciept:
BRCLMP, 4-3/8
UPC: 025104345581
From the reciept:
BRCLMP, 4-3/8
UPC: 025104345581
The stock front 350mm rotors weighs 26 lbs, the stock rear 330mm 19.5 lbs, and the Cup rear 350mm weighs 22 lbs.
