Anyone running 18x9 up front?
Looking for input for the widest wheel size for the front. I am thinking about an 18x9 ET52 in the front.
Anyone have experience running that width in the front? Clearance issues, etc? use a spacer to push it out about 5-7 mm?
Thanks in advance.
Thanks in advance.
Below is what I used to run on the track without any clearance issues. I have the SX3s on the car for street use, but use the stock size tires.
Forgelines SX3-R
9x18 ET 49, 245/40 -18
11x18 ET 64, 305/30-18
Forgelines SX3-R
ltcjmramos,
Thanks for the input and confirmation of what you are using. It sounds like my ET52 would be sitting only 3mm further inboard should not be an issue. If it is then a simple small spacer 3mm will place the wheel exactly where you have yours.
Originally Posted by Z06
NJ-GT is using a 10" wheel.. do a search
This info is from way too much reading of older posts.
Cheers,
It's realy in the set-up... I was running a 265 tire on the front no problems. I now use a 9" rim with 245's. I run at Mosport and do not have a problem with understeer...it's all about rear end grip.
Thanks in advance.
Thanks in advance.
