Time needed to install muffler bypass pipes
It seems that the Fabspeed muffler bypass pipes are a very good option to reduce weight with the negative of a very LOUD sound for the road.
Excuse my ignorance... Can it be (easily ) installed/un-installed by a good mechanic when going to / back from a track ?
Thanks in advance ...
It's an easy DIY job. Your mechanic should have no problem.
1. Loosen the post-cat clamp and slide it out of the way.
2. Remove the 3 nuts holding the muffler in place (via the bracket).
3. Remove the entire muffler with the tip attached.
4. Line up your muffler bypass pipe.
5. Slide the post-cat clamp over and tighten.
6. Repeat for the other side and you're done.
It's helpful to get the rear up on some ramps.
Originally Posted by GT3 Nut
Nope. It is a very easy job. It takes about 30 minutes.
I remove the rear wheels as well, just for more clearance. I found it much easier to do that way. Otherwise, the above steps mentioned are what I do.
Enjoy! I love mine...
Question for the 1/2 hour guys. Can I hire you for 1/2 hour at the typical Porsche shop rate ($100/hour) to get my bypass installed? I prefer to pay the $50.
