Why always Pagids when chosing pads?
29 replaces 19. Using the 14 compound (more agressive) in the rear adds some rear brake bias. The proportionately small front tires on our cars can only do so much. Moving bias to the rear helps use all that rubber out back and improve stopping performance.
To be honest I don't recall. I called up PFC, told them that I was using the car exculsively for DE and club racing (no street) and they recommended the compound. The difference between the PFC and the Pagids are the amount of heat they transfer. The RS series pagids use a ceramic coating between the pad material and the pad plate which reduces heat transfer.
Thanks Dell and that is why I would love to hear more seasoned guys/racers chime in.
After working with David Murry I have practiced more and more on trailbraking. I feel as if the hard initial bite I get with the RS-14s up front is more of a hinderance to me doing this well than are the RS-14s in the rear.
I felt after all the reading, listening and research I had done that the RS-19s up front were the way to go.
It's just that when the shop that you work with and tracks your progress mentioned that I should give the PFCs a try I thought I should at least listen.
I am also just now putting on new Brembo FH on the front and don't want to be swtiching back and forth between pad material.
I can use all the help I can get.
Yes, technically the 29 and 19 are different. My understanding is that the 29 will be slowly replacing the 19. Here is the info from Pagid...
RS 14 Black - Medium high friction racing compound with high initial bite, excellent release characteristic, very good modulation (controllability) and due to the high ceramic content low heat conductivity. RS14 has a low wear rate and is fade resistant up to a temperature of 650°C (1,200°F). Applications: Touring cars, Rally cars (tarmac), GT cars, WSC, DP, single-seaters, NASCAR .
RS 15 Grey - High friction racing compound with high content of ceramic materials, fade resistance up to 700ºC (1,300ºF). It combines a 20% higher friction value than the RS14 with a slightly increased pad wear. Although the RS15 has a good controllability and release characteristic it needs finesse to avoid over braking the car, especially with lightweight cars or cars with boosted brakes. Applications: Touring cars, Rally cars (tarmac), GT cars, WSC, high down-force single-seaters, NASCAR.
RS 19 Yellow - Best compound for endurance racing on the basis of the RS14. A slight reduction of the friction value improves the modulation (controllability). Nevertheless, the friction value is enough for cars without power-assisted brake system and ensures comfortable low effort on the brake pedal. Constant temperatures up to 600°C (1,100°F) are possible. The combination of friction value, fading stability and low wear rates on pads and discs (rotors) realised with this material is unmatched up to now. Due to its excellent release characteristics and controllability PAGID endurance materials are also often used for sprint races. A multiple winner of Daytona 24h, Le Mans 24h, Sebring 12h, Spa 24 h, Nürburgring 24h, often with no pad change and usually no disc (rotor) change. Application: All endurance racing cars from Group N (Speed-WC, Grand Am Cup), Group A up to GT and Sport-Prototypes (Grand Am DP).
RS 29 Yellow - RS29 combines the outstanding wear rate of the RS19 with a slightly higher coefficient of friction and initial bite. Due to its excellent driveability PAGID endurance materials are also often used for sprint races. Application: All endurance racing cars from group N (Speed-WC, Grand Am Cup), Group A up to GT and Sport-Prototypes (Grand Am DP).
I have read the pagid info Ed. Exactly where do you get your "udnerstanding" from? Pagid themselves has stated that the RS29 is NOT a 19 but rather a 19 with a higher coefficient of friction. FYI...this was discussed a few months ago. Forgot who confirmed the "rumor" was false that the 29 was to replace the 19 but do a search for the thread and you will find the discussion.
The info was from Pagid over the summer. I called them to ask about running the RS19/RS14 with my GT3 brakes as compared to the RS14/RS14 I was running with the stock brakes. The RS29 was not out yet and they told me it would be replacing the RS19. Quite likely things have changed.
Originally Posted by GT3 Nut
I thought they were "P50", but not sure. The 996 street GT3 comes with "P90" pads, which are in fact painted yellow but they are NOT the RS19's which is commonly referred to as "yellows".
-Juan
Originally Posted by 9juanjuan
So what's the difference between the "P" number compounds vs. "RS", and where can I find the description for them. The Pagid site doesn't have any information on the P numbers, only RS.
-Juan
-Juan
Just a thought - "P" is simply for Pagid and "RS" is for race series?
Probably NOT, but hey like I said I don't really know.
What I do know is that the P90's that come on the 996 GT3 stock don't squeel like the RS4-4 or RS14 or RS19. They seem to be much softer as well.
