GT3 Seats - Installation Question
I'm installing 996 GT3 seats in my 986S.
Did the driver's side tonight. All's fine, except for a problem with the seatbelt. The female receptacle is wedged betwen the rear center console and the seat. It's pulled up as far up as it will go, but it ain't far enough. Anyone know how to address this problem?
Here are a couple of photos...
GT3 player par excellence
thats about where my receptacle is at. it works fine.
Thanks for the replies. The belt works okay, but it seems like it should go a little higher to avoid scuffing the center console, or hindering the seat's movement on the sliders. But I guess this is properly installed.
I thought the preferred routing of the outside belt was over the edge, not through the slot as you've done, for two reasons:
a. Through the slot creates additional tension on the belt, very bad if there's a collision, and
b. Through the slot will interfere with the additional outside lapbelt of a five or six point harness, if there's any plan to use one, and screw up your ability to engage also the regular belt, which is the only way to stop the reminder gong and shut off the warning message.
Anyone know the routing used by the Factory on the European 996 GT3s?
Richard Bain
Richard Bain
Richard Bain
Richard Bain
Richard Bain
Richard Bain
Well, someone is very wrong, and it looks like it might be me. If so so, I put the blame on my mechanic. The only way to find out for certain what's the correct routing is to determine how the belts on the European 996 GT3s ( which as you know came with these seats as standard equipment) were routed.
Would one of our European correpondants who owns/owned a 996 GT3 kindly post the answer here.
Richard Bain
Richard Bain
When I installed mine, there were a number of threads on this issue and someone posted the pics you're looking for.
Have you tried doing a search? Probably a lot of stuff to weed thru.
I think there was no definitive answer on the lap slot routing, some of the European cars/pics did go through and others didn't. My conclusion was that it did not matter much as long as there weren't any binding/convenience issues, typically with harnesses. I went back and forth with my routing about half a dozen times...
The most important point, though, was to bolt the OEM belt to the chassis, and NOT to the seat.
Well, today we installed the passenger seat with similar problems with the three-point seatbelt receptacle.
Solution: my friend is going to machine a couple of steel extension pieces, and we'll install these over the weekend. They will extend the seatbelt receptacle 3.5 inches higher. I'll post further photos when they are ready.
Richard Bain
Richard Bain
I wouldn't add extensions for the receptacles but instead remove the square block spacers on the side where they mount. This is what I did on my 964 since they were stuck against the tunnel.
