Carpet removal (GT3 MK1)
Hi there,
Eventually I sold my 993 RS look-like for a MK1 GT3 Clubsport.
I spent 5 days to remove the carpet from my 993 (I should say remove the glue behind the carpet) and I wanted to know how easy it was to do the same on my GT3...
When I look at different pictures of GT3 without any carpet left I assume that there is no more glue to remove but maybe I'm wrong.
If anyone has the answer to my question, would be really greatful!
Thanks in advance!
Thanks in advance!
Extremely easy.
Only the passenger side front carpet has a little bit of glue on right side.
When removing the front carpet, it's better to cut around the shifter and handbrake, than removing the entire assembly. When reinstalling, use velcro.
Carpet Weight:
Front: 12 lbs
Rear floor: 12 lbs
Rear seats: 8 lbs
GT3 Panel: 4 lbs
Struts cover: 2.5 lbs
Carpet Weight:
Front: 12 lbs
Rear floor: 12 lbs
Rear seats: 8 lbs
GT3 Panel: 4 lbs
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
Originally Posted by NJ-GT
Carpet Weight:
Front: 12 lbs
Rear floor: 12 lbs
Rear seats: 8 lbs
GT3 Panel: 4 lbs
Front: 12 lbs
Rear floor: 12 lbs
Rear seats: 8 lbs
GT3 Panel: 4 lbs
Extremely easy.
Carpet Weight:
Front: 12 lbs
Rear floor: 12 lbs
Rear seats: 8 lbs
GT3 Panel: 4 lbs
Carpet Weight:
Front: 12 lbs
Rear floor: 12 lbs
Rear seats: 8 lbs
GT3 Panel: 4 lbs
Thanks a million for that and Happy Holydays to you and your family!
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
GT3 player par excellence
hey rad, you NEED to buy a 997gt3, if nothing else, we poor RL all need these data points as you experiment with your new car, LOL.
best,
best,
If you don't care about keeping the sound deadening, but also don't care about the glue residue, how hard is the carpet removal? I'm considering switching colors and putting in new sound insulation, so I don't really care if there is some glue residue, but I don't know how hard it is to remove...
