996 GT2/GT3 Forum 1999-2005
Performance 996 vs 997 GT-3
Old 06-11-2006, 12:28 AM
allegretto
allegretto's Avatar
Default Performance 996 vs 997 GT-3
I know the released data says 381 vs 415 HP.
Does anyone know more specifically how that increase is produced?
Old 06-11-2006, 05:16 PM
10 GT3
10 GT3's Avatar
A few of the changes are a different intake air box, larger throttle body, different heads, higher compression and a less restrictive exhaust.
Old 06-11-2006, 06:38 PM
GrantG
GrantG's Avatar
Received 5,164 Likes on 2,909 Posts
Aside from what's listed above, the internal parts are lightened, allowing 200rpm more revs. This with better breathing and more compression means more power...
Old 06-11-2006, 08:13 PM
stuka
stuka's Avatar
The lighter internal parts are soon then counteracted by that nice hole on the roof that will come mandatory on every shiny new 997 GT3.
Old 07-10-2006, 10:51 AM
1999Porsche911
1999Porsche911's Avatar
The bore is larger and the stroke is shorter in the Gt3. This, by definition, allows for higher revs. Throttle grew to 82 mm if I remember correctly and varioram was modified. Variocam range also increased.
Old 07-10-2006, 11:47 AM
997Vancity
997Vancity's Avatar
how much weight does sunroof add?
Old 07-10-2006, 12:54 PM
MetalSolid
MetalSolid's Avatar
The 996GT3 was really more like 400bhp... Let see if the 997GT3 will be more than 415bhp...
Adds as much weight as the expensive $8000 PCCB option removes.
Old 07-10-2006, 03:43 PM
RR
RR's Avatar
From every article that Ive read on the 997 it doesn't seem to be worlds ahead of the 996. The consensus sounds like it is a car that can now be driven closer to the limit much easier than the 996 could be driven. Other than the HP which is - relative since the 996 was blowing more or at least close to 400HP already - sounds like the biggest "improvement" in the 997GT3 is the removal of some of the bumpsteep/feedback.
Old 07-10-2006, 05:48 PM
frayed
frayed's Avatar
The stock power on the GT3 was quite adequate, as is the power on my 997S and I'm sure the moderate bump in hp will be nice but hardly worth the cost delta.
My bet is that the new GT3 will be worth the money, not b/c of motor, but b/c of chassis improvements.
Old 07-10-2006, 06:43 PM
GT3smitty
4th Gear
GT3smitty's Avatar
Can anyone validate that the 997 Cupcar actually uses an engine more closely resembling the 996 GT3 specific engine and internals rather than the 997 GT3 and its internals? I had read somewhere that this is in fact the case. If true, it would certainly be interesting! Thank you.
Old 07-10-2006, 06:57 PM
Glen
Glen's Avatar
7 has longer rods also...
Old 07-10-2006, 10:17 PM
NAAMAZ
NAAMAZ's Avatar
Or you(one) could lose the 20 lbs off your *** and/or prove that you are that much faster with out the hole, or just quit the bitching and buy a cup car, if you are really that good...I know its not the hole its the principle.....yada yada yada....Let the slam begin, not directed at anyone, just to the general stupidity of the anger about the hole.
Old 07-10-2006, 11:29 PM
Phokaioglaukos
Phokaioglaukos's Avatar
450? I heard 465.
Old 07-11-2006, 12:26 AM
XSpeedFreakX
XSpeedFreakX's Avatar
465? BS! I heard it was closer to 480.
Tim
Old 07-11-2006, 12:42 AM
MetalSolid
MetalSolid's Avatar
505 when you press the sport button!
Quick Reply: Performance 996 vs 997 GT-3
