GT3 seat install....battery disconnect or just key out of ignition, ok?
Title says it all. Is the key out of the ignition sufficient or do I need to disconnect the battery as well?
TIA
TIA
GT3 player par excellence
well, it is summer of 2006 here in CA.
so you got the car?
i disconnected the battery and it worked. never tried the key out of ignition method.
so you got the car?
Yup, just key out, put it in the door. Don't listen to the radio during the procedure
Also during the procedure if you flip the door latches to "closed" the lights on the doors will turn off to save the battery. To unlatch, just lift the handle as if you were opening a closed door.
Austin
Austin
I went ahead and disconnected the bar since I had the harness bar, the seats, and a few other misc projects. All done though.
Appreciate the input from everybody!
Of to the track in the morning :brunout:
have fun dell.
now you are experience in installing all the fun stuff, i bet the itchy for GT3 is getting worse LOL.
Well, just got back from the track and the seats were fantastic! Bad news is my weekend is over. Blown oil/air seperator
Loaded her back in the trailer and came home to a matini!
sorry to hear about the oil/air separator issue. that should be covered by wty.
