Valentine One Hidden Mounting
How can one mount the Valentine One such that it's hidden?
Anyone have pics of both the unit and the remote display unit?
Here's my thoughts - if a cop does pull me over, I am getting a ticket if he sees the system. How can I set it up so that it's hard to see from out side the vehicle?
anyone with photos?
Thanks!
anyone with photos?
Thanks!
I have looked a bit too.....but I cannot find a decent place to hide it. In my M3, I used the 3rd brakelight housing to mount it. Worked like a charm and it was 100% concealed.
On the GT3, there just isnt a good place for it. i clip mine to the drivers visor. It is VERY hard to see from the outside of the car.....and you would reallyhave to stoop low and look "up" to see it. That is about the best place I could find.... let me know if you figure something better out.
I have doubts that a cop could see the detector from distance, so why bother to hide it. I keep it within arm's reach on the windshild where it gets optimum vision in either direction. If I get hit and they come after me, I simply lift it off the glass, pull the charger cord from the aux. plug, and either drop if behind the seat where there's always a coat, towel, etc., or put in the center console of my MBZ. You do this the minute you see them start moving, and with minimum body motion so as to not alarm them. Same thing if a cruiser passes from behind....
In Ca it's perfectly legal.
I am mounting mine next week.
The V1 needs to be in a spot where it can clearly get signals.
So it needs to be mounted where you can see it.
The best thing to do is have the concealed display low and away from any easy viewing from the windows.
The point for that is so when the V1 gets hit, the arrows don't flash where a cop behind you can see them.
My V1 will be hardwired to the car.
The V1 will be suctioned to the windshield.
The display will be concealed right below the CD holder in the little storage compartment. (Basically right above the shifter)
Now it is legal in CA, but you don't need to be a dead giveaway with a flashing V1 and a power cord from the cig lighter adapter.
Will do, I just ordered a new wiring kit, when I traded in my C32 I could not frantically get it out..lol
https://store.valentine1.com/store/
Z06Kevin, your solution is to get a Cup Car like JR's... then you can slap the V-1 anywhere on the windshield and the fuzz won't be able to see it due to that sweet wing in the back.
Since the receivers are within the V-1 unit, you need to mount it where it has a clear view of the road ahead and behind. Hardwire the V-1 from the headliner and mount the detector just under your rearview mirror. Mount the remote display in the center cubby... all lights will be routed to the remote display and the main unit will always stay black.
I do not recommend mounting the remote display on the steering column or in other somewhat hard to reach places since you will frequently need to hit the mute button on the remote unit. When it beeps in the center cubby, you just slide your finger over off the shifter and it's muted.
Some pics in my C2. The install should be the same in the GT3.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Our GT3 has a Valentine mounted to the right and behind the windshield mirror. I can't see it from the drivers seat. It is not obtrusive from the passanger seat.
A Valentine remote display is behind a smoke colored plastic panel in the spot where the 4-way flashers were. Easy to see.
The 4 way flashers switch function is moved to the top left switch spot to the left of the HVAC panel.
Very Trick.
Mounting done my La Jolla Audio, who has mounted Valentines in all my cars.
vvvince Knauf
San Diego
Very Trick.
vvvince Knauf
San Diego
Official Wednesday AM Red Bull F1 test driver
I've got the remote display right on top of the steering column where it's easy to see and doesn't block any important lights. Used to have it under the dash where the console used to be but it was harder to see- where it is now you can see the lights out of the corner of your eye without looking from the road. The main unit is to the right of the mirror up high and reasonably stealth...
It's all a matter of personal preference.
Cheers
If a cop pulls you over at warp drive, whatever you have in your car doesn't make any difference.
If you were close to the limit then you got pulled over it's because of what you were driving. You'll either not get a ticket because the cop thought your car was cool, or get a ticket because the cop is jealous.
