Preventative maintenance on a GT3 track car
The car has approx. 11k track miles this year and I would like to avoid problems at future events. The car has not failed me yet but I feel that something has to give. Have changed all fluids many times, brakes, rotors and tires but, that's about it. Mechanic said my sway bar bushings are loose but that's all. Should I consider changing wheel bearings or possibly be changing suspension parts? Anybody have any suggestions?
Ya I know, A little excessive I guess. I've given up trying to count # of days, I just look at the odometer. A little over 17k km. Have done 7 days of track in a week once and several times have done 5 or 6. It's all kind of a blur.
I have an appointment at the dealer tomorrow before heading off to VIR. Just wondering if anybody had any suggestions.
GT3 player par excellence
man i must be getting old. i got about 24 track day this year and 5k of track miles. you and cosmos are amazing...
I dunno if I'm more impressed by the car surviving 7 days on the trot, or you for doing it. I bought my GT3 RS because my Noble needed constant fettling. Stories like this just confirm my decision.
Roberga, that's great to hear. You haven't changed wheel bearings or any bushings or suspension parts. I have a feeling ( mechanic suggested as well ) that there may be some play. My mufflers sound like a set of marracas, they're toast. Cats too I think.
also, if you want the car working really well,fiorano has a set of revalved and refreshed stock shocks and they will make a big difference to your car.
I too have about 12k track miles on a car that has 19k miles overall.
I re-did my shocks as well. I did not relize how far blown they were.
PNA replaced my Diff as that was blown too. But I think that went early on.
I have asked and no one can tell me what to do.
I did a leak down and compression test as well as scope the engine and my Mechanic said it looked new and that the compression was the best of any car he as ever seen. Almost no varience between cylinders.
I also replaced the rear arms with cup ones and the rubber bushings with metal for the arms as well. This just helps with setting the toe and makes for easier adjustments.
I was thinking that since I track so much, that I should run maybe the RS spark plug, any thoughts on that one??
My wheel bearings seem fine so far. Should I just replace them anyway??
So I will ask the question too. What else should I fix, or look at fixing or replacing.
I am more worried about the rubber on the car. What about any rubber up front, how are the tops of the struts or front control arms??
Thanks,
Thanks,
Thanks,
Thanks,
Originally Posted by mooty
i replaced both my front bearings as they were very noisy.
...dealer did it under warranty for free. yes they knew i tracked the car and didn't care.
Dealer should be obligated to replace non-consumables, under warranty.!
I would be very upset if OPC in UK, charged me for any non-consumable item on the RS, because of trackwork..
These cars are sold purely on their track ability, and road car rules should not apply, re-warranty.
Rob
Ok, replace all four??
How many hours of labor and how about price?
