RMS Leak... take II
i had a leak in my GT3 (big puddle on the floor of the garage) and then after leaking about a quart (4 bars missing on the gauge), i added a quart, and it stopped leaking?!?!?
some asked, did i over fill? answer - i have never added a quart of oil to my car other than oil changes. the last oil change before the leak was 3 months prior ...
Healed RMS?
Healed RMS?
Well the car is fixed... hopefully for good this time around. My SA told me the RMS they used is a 993 part. I'll post up the part number once I pick up the car and paperwork this afternoon.
I wonder what the chances are of me getting a new engine should she leak again.
I wonder what the chances are of me getting a new engine should she leak again.![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
AFAIK, its the standard 993 RMS. Not sure what exactly happened to using the Cup/RS part they were telling me about... unless those use the 993 part. I forgot to grab my paperwok on my way out , so I will have to post the part number tomorrow.
Originally Posted by Phokaioglaukos
I may now have reason to ask for this part number. Do you still have it?
Never got the actual part number. Its the standard 993 RMS with the spring to keep the tension on the crank. I know there was a thread floating around that had pictures of the 996 part and the 993 part.
King of Cool
Originally Posted by M758
964's and 993 had occasional Rear Main leaks too... right?
Technical Guru
I hear if the cars are not driven at least once weekly, the seal can dry out a bit and start to leak. After replacing the first one, 3 weeks later it leaked. I drove 8 hours round trip to Watkin's no leak after that last fall. Probably started the car every two weeks over the winter. Mine was leaking again this Spring.. a drop or two on the floor. Went to Limerock two weeks ago...just checked underneath the car and voila...NO LEAK. It looks like it can repair itself if you go out and run the car well and or drive it at least once a week. I'm not too concerned about it anymore. When the warranty period is close to ending and it's leaking, I will take car of it then and maybe upgrade the pressure plate ad or replace clutch disk if necessary...
Originally Posted by JasonAndreas
If you order one from PMNA ($70.39USD) this is what you get
![](https://members.rennlist.com/jandreas/996-GT3-CUP-RMS-DIF.jpg)
the regular 964/993 seal is only $20USD.
The dealership threw it on the lift this morning. Sure enough, its leaking from between the engine and tranny. They are going to fix it again using the RS spec RMS. Something about it being spring tensioned and a better part than the standard one. Anybody familiar with this?
Originally Posted by GT3 Chuck
didn't you say you had the RS crankcase vent...if so then the RS seal would be a better choice
FWIW... The second RMS is still dry and I haven't driven it much at all the past several months.
