GT3 Pagid PS 19 Brake Squeal
#32
Originally Posted by mooty
you mean your car was not aligned by tony previous to today?
all i know is that his alignment numbers are not the same as what most ppl use on RL, but it works great for me and fong.
haha, now that you like it, you should keep it.
#33
Originally Posted by brucegre
Cosmos, I tried them at Shannonville (very tight, ####### brakes, highest speed is about 130) and they were awesome. This was in combination with the Brembo floating rotors, it was just great stopping power with none of the shake that we get so used to. I can't wait to try them at Trembant and Mosport, where the speeds are higher.
I'll report back after I have more track time on them, but so far, big thumbs up.
Bruce
Bruce
I've not used RS19s though, so can't compare directly.
#34
I am running RS19s on PCCBs. They seem to work fine (so far) and bedded in nicely.
I had forgotten how loud the PCCB discs sound when braking. It is like a saw almost.
Also, having driven the car back to back with PCCB and without (AGAIN), I still think the weight is the primary difference between the two. I can not tell an improvement in either pedal feel or performance.
The weight difference is very obvious in the way car feels (light) and IMHO accelerates quicker too.
#35
i put pagid rs19 on my 997s w/o vibration dampers (pads were too thick). car screamed, squealed at the slightest touch of brake pedal. after a couple of track days i installed the front dampers. squeal is completely gone.
#36
I wonder how many heed the warning from Pagid about avoiding contamination of the disc surface by renewing pads on old discs without going over the disc surface with emery cloth to remove previous pad residue.
If you are swapping pads around most Pagids are compatible so should not be an issue but if you are swapping back to stock or another manufacturer your brake performance, according to Pagid, is compromised.
#37
Still plays with cars.
The Pagids are compatible with the OEM pads on the GT3.
