Corner balance with a half tank?
I've read here that one should corner balance with a half tank of gas and a weight in the seats as you'll have on the track. That makes sense, a half tank of gas will split the difference between full and empty for balance (except that 3/4 tank might be a better "average" for street driving). The Porsche manual, though, says to set the ride height with the tank full, and that makes sense as having maximum weight in the car will compress the suspension more than a half tank--you wouldn't want to set the height and then add gas and end up too low.
So, what do you do and recommend? Tank half full, full or something else?
Still plays with cars.
Half a tank and the driver or equivalent weight in the driver's seat. You do this after having set the ride height correctly as per the book. The change in ride height needed to corner balance is quite small. Unless you track the car there is no need to corner balance.
Rgds,
Rgds,
Viken I agree. The procedure you pasted is for setting the ride height. One should do that first, then do the corner balance with a half tank of fuel and the driver in his seat.
Best,
Best,
Keeper of the Truth
Viken,
I saw nothing in the posting about corner balance. Since the driver weighs a lot, I cannot imagine doing a corner balance without his weight in place. All the instructions I have ever seen have the driver or equivalent weight in place. My 180 lbs on the left side has to affect the corner weight. You planning on being out this way this summer? We have a DE right after the F1 race...
Best,
Best,
Keeper of the Truth
Bob, do you set the height with a full tank and no driver, then siphon out half the tank and put a weight in the driver seat to corner balance?
Viken, what do you do?
Keeper of the Truth
Pho - I do it in two steps set the ride height as per the book (above) and then bring the car back for the corner balance with as close to a half tank as I can.
Jason - no the DE is at Le Circuit Mont Tremblant. A nicer circuit than the Grand Prix in my opinion. It's about 75 miles North of Montreal in the middle of a 4 seasons resort.
Best,
Best,
Keeper of the Truth
Originally Posted by 993_996_enthusiast
I don't think Porsche AG will address corner balancing for a street model due to legal issues. It implies "racing" use.
Perhaps because corners on the autobahn at 240 KPH require a betteer balanced car?
Viken
In what you posted from the manual I see the instructions for 'lateral' weight balancing but not 'longtitudinal' front to rear (other than advising one to keep the front to rear ride height difference within specs). So, I stand corrected in that they are doing a partial corner balance.
I still don't understand their emphasis on lateral balance when they don't place any weight in the driver's position?
The GT3 Cup manual states, "Car to be measured with 1/2 Tank of fuel and 75 kg in the drivers seat. Joint and wheel bearing play checked (wheel bearing play can not be adjusted). Front and rear tyre pressure set to 2,0 bar."
