996 GT2/GT3 Forum 1999-2005
Sticking GT3 engine in regular 996
Old 03-24-2005, 04:40 PM
  #31
Viken
Keeper of the Truth
Viken's Avatar
Originally Posted by RayGT3
You'd also have to hammer out a place for the oil tank. I believe these areas are specific to the GT3 or anything with a dry sump.
The oil tank sits right on top of the engine just below the rear deck.
Old 03-24-2005, 04:42 PM
  #32
1999Porsche911
1999Porsche911's Avatar
Ahhh...the children on this tread make a funny. How about growing up boys. The fact is, if you do not track your car, your shocks on a 996 will provide you a lifetime of safe, confortatble service. (well over 100,000 miles) I guess you are of the breed that also only gets 20,000 miles out of a clutch.
Old 03-24-2005, 04:43 PM
  #33
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
1999 - sorry, I didn't mean to dis your supercharger (I'm guessing you have one) but can it be removed without leaving any evidence behind? Perhaps a hole for another injector or a modified ECU?
There are two supercharged cars in the local club. One is a C4S (993) with a kit which is an abortion - there is no way the car can be returned to stock and after a year when the ownere tried to trade it in no dealer would take it. Perhaps the 996 installation (or another supplier's kit) can be removed without evidence. I suspect a dealer would spot the changes though and might not want it in trade. As you say, if you drive them to the point where resale value is unimportant then it doesn't matter at all.
GT3 seats and the Techart roll bar are bolt ins with no holes to drill. The seats can be swapped out in less than 30 mins. My original seats are sitting in plastic wrap waiting for the next owner <grin>.
Best,
Old 03-24-2005, 04:52 PM
  #34
RayGT3
RayGT3's Avatar
Viken,
I don't think the standard C4 chassis has the recess for the oil tank in the rear deck. I don't know if they rework the standard deck on the C4 or make a special one to accomodate the oil tank.
Old 03-24-2005, 04:54 PM
  #35
1999Porsche911
Bob:
The 993 SC is a totally different animal than the Centrifuge system on my 996. There are no additional injectors, just higher flowing ones. No modifications of any sort to body and all componants are easily removed and stock componants re-installed. The only thing I would leave from the system is the 3rd raditaor which I would plum to the cooling system rather than the after-cooler. The DME is reflashed to stock specs.
Old 03-24-2005, 04:56 PM
  #36
Cupcar#12
Cupcar#12's Avatar
100K miles on shocks - Huh?
Old 03-24-2005, 04:58 PM
  #37
1999Porsche911
On a street driven 996 or any other quality car...no brainer.
Old 03-24-2005, 04:59 PM
  #38
Phil
Phlat Black Guru
Lifetime Member
- Times 2
Phil's Avatar
Yes, ITS A FACT just ask 1999porsche911
Old 03-24-2005, 05:01 PM
  #39
Mike in Chi
Mike in Chi's Avatar
Really? Is that right?
I have 18,000 miles on my car and I'd swear my 8 year old shocks have had it. But these are on a 993. Maybe the factory put better ones on the 996.
I did track that car once, at Road America. Would one track weekend wear them out (it was raining)?
I was going to replace the shocks with PSS-9 and a bigger bar. Should high performance suspensions last 100,000 miles too?
How long should a set of brake pads last?
Old 03-24-2005, 05:04 PM
  #40
1999Porsche911
As for the brakes, if you don't track you6 6 speed car, but otherwise drive your car hard, but properly, anything less than 40,000 would be low miles on the original brakes. You should get 50,000 plus on the fronts.
Old 03-24-2005, 05:06 PM
  #41
Greg Fishman
Greg Fishman's Avatar
Not a chance. Maybe 25k-30k if you don't drive hard.
Old 03-24-2005, 05:09 PM
  #42
Phil
Phlat Black Guru
Lifetime Member
- Times 2
Phil's Avatar
what does the transmission have to do with brake wear?
Old 03-24-2005, 05:10 PM
  #43
1999Porsche911
Well, stop by and see car. Almost 50,000 miles on my factory orginal brakes system, including pads. But I guess it must not be true because you said it can't be. Maybe I am driving with no brakes?
Old 03-24-2005, 05:12 PM
  #44
Greg Fishman
I guess that is another improvement they made on the 996 over the 993.
Old 03-24-2005, 05:19 PM
  #45
Mike in Chi
Would you define "driving hard, but properly"?
Those are longer lives than I've heard of for consummables.
Quick Reply: Sticking GT3 engine in regular 996
