996 GT2/GT3 Forum 1999-2005
GT3RS clutch and flywheel
Old 02-06-2005, 02:26 PM
gtdrei
gtdrei's Avatar
Thumbs up
IMO for a GT3 the RS flywheel is a must. The chatter noise is minimal
I agree, I also find the clutch easier to use, and haven't even come close to a stall. No negatives to this upgrade, IMO.
Robin
Old 02-06-2005, 10:52 PM
healeyg
healeyg's Avatar
but what about the cpu remap? i thought that was needed to take advantage of the throttle response issue? can you get an RS map?
Old 02-07-2005, 02:11 AM
gtdrei
gtdrei's Avatar
After reading the Excellence article on the RS, before pulling the trigger on the Flywheel/clutch conversion, I was concerned about that. Other GT3 owners who had done the RS flywheel conversion all reported much improved throttle response, without the remap, IMO, the RS remap has more to do with the whole RS engine package, which is more than just the flywheel/clutch.
The lightweight flywheel used to be an option, without 'remaps'. the 1994 RS America was offered with either the dual mass flywheel, or the lightweight flywheel ( the same part # as today's GT3RS uses), with a much cruder ECU.
You'll also need an RS key code to get the remap, and that will be really, really tough. Bottom line, it works really well and is a big improvement
Old 02-07-2005, 07:06 PM
Ghost
Ghost's Avatar
Again, thanks to all. It seems the RS clutch and flywheel package has many positives and, from what I can gather from your posts, not a single negative - besides the cost! My only question is where in the heck can I find a shop willing to tackle the project in the greater Lancaster/Philly area?
Old 02-07-2005, 08:10 PM
Cupcar
Cupcar's Avatar
Not to put too fine a point to it, but the RSA did not have the LWF as an option. The European RS had the LWF standard but with a different ECU. There have been many complaints about stalling, particularly with A/C on, from those who have installed the LWF on aircooled cars.
I have not read a single complaint about stalling on the water cooled cars with a LWF.
Old 02-08-2005, 01:08 AM
gtdrei
gtdrei's Avatar
My mistake. Most of the people I know with RSA's around here have the LWF.
Robin
Old 02-08-2005, 02:47 AM
03-turbo911
03-turbo911's Avatar
The euro GT3 also comes with this flywheel as standard in the clubsport spec. It's not only for the GT3rs.
Old 02-08-2005, 10:33 AM
RR
RR's Avatar
No it doesn't.
The MKI had the light flywheel.
The MKII only gets the roll cage, fire extinguisher, and the GT3 seats, 6 point belt for the driver and battery master switch in the cockpit.
Old 07-05-2005, 09:27 PM
rockitman
rockitman's Avatar
Everyone still happy with their RS Flywheel/clutch setups? 95% sure I have an RMS, so might as well change the stock fly/clutch out since they need to come off anyway. Awaiting approval from my dealer as far as doing this...Are there warranty issues as per PCNA that would void my car warranty ? Thanks
ps: just curious if anyone who has done this, did their dealer requires PCNA approval ?
Old 07-05-2005, 11:12 PM
WULF
WULF's Avatar
You will love it. Change to a 8:40 pinion/crown while your there. Should be no warranty problems but then I'm on a different continent.
Old 07-05-2005, 11:17 PM
rockitman
rockitman's Avatar
And what continent would that be Mr. Wulf ?
Old 07-05-2005, 11:18 PM
WULF
WULF's Avatar
Australia
Old 07-05-2005, 11:23 PM
rockitman
rockitman's Avatar
Australia
ahhh. Gday Mate !
Old 07-05-2005, 11:33 PM
WULF
WULF's Avatar
'owyer goin'
Old 07-06-2005, 01:39 AM
gtdrei
gtdrei's Avatar
Default LW Flywheel
Rockitman,
Ah, extremely happy. No remap, and I run 92 octane (mostly) The LW flywheel is definitely the way to go. And while you're at it add the 3.8RSR clutch. I can't answer the warranty issues question, it seems to be dealer dependent.
Robin
Quick Reply: GT3RS clutch and flywheel
