A Question For The Part No. Masters :)
Can anyone give me the part numbers for:
1. Porsche GT3 Seats (bucket seats)
2. Porsche Tequipment RollBAR
3. Porsche OEM 6 Point Harness (Schroth)
4. Porsche Belt Subbraces (Are these included when ordering any of the above? or are they a separate item?)
5. Any other parts/part no.s that may be involved in the installation of the items.
Thanks very much!
Thanks very much!
There are two roll bars, 996.580.981.00 is designed to install a 6 point harness, 996.580.980.00 is a simple hoop not designed to support a harness.
Schroth 6 point harness is 996.803.037.91 Left and 996.803.038.91 Right.
The 6 point harness mount for under seats is 996.521.933.90 you need one for each side.
Part number on seat depends on what kind of cover you want on it, Perlon or Leather.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
thanks so much cupcar!
the seats in question are Leather. would love to know the part no. for those.
is there any more relevant parts involved in the installation of these things?
i assume these 4 'primary' items include smaller kits for the installation.
It is not completely clear in the parts list but it looks like both roll bars come as a kit that includes mounting hardware.
The seat belts are complete but do not include mounting bolts (at least they are not pictured), presumably the originals are used.
The seats come complete with all mounting hardware and are a bolt in.
The 6 point harness bar that goes under the seat apparently uses the same bolts that secure the seat tracks.
The seats for a left hand drive car are 996.521.985.01 Left and 996.521.986.01 Right
The suffix added to the part number determines the color:
8YR=Black
B50=Space Gray
C50=Graphite Gray
G10=Metropol Blue
S30=Savanna
J30=Nephrite
M30=Boxster Red
T11=Brown
DOUBLE CHECK ME ON THESE NUMBERS A TYPO IS EASY TO MAKE
8YR=Black
B50=Space Gray
C50=Graphite Gray
G10=Metropol Blue
S30=Savanna
J30=Nephrite
M30=Boxster Red
T11=Brown
The OEM 6-pt belts I purchased from Gert included mounting hardware - a set of longer bolts and sleeves that allow you to mount both the 6-pt lap belts and the stock street belt connectors along the sides of the seats. Everything bolts together easily and works well. If you want a fire extinguisher on the passenger seat, buy only one factory subbelt bar and get the other from BKAUTO which works with their extinguisher mount bracket.
You
're welcome.
You may want to check the forum for installation tips, things such as disabling the seat belt light and I hear the roll bars are a bit of a tweak to install.
Should be a fun project though.
i dont need to install them, i already had them all installed in my GT3, im getting these numbers for a colleague, who is planning to do the same thing
cheers!![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
here is mine:
cheers!
here is mine:
![](http://gallery.rennlist.com/albums/gt3/DSC00137.jpg)
99652193390, 99652198501, 99658098000, 99658098100, 99680303791, b50, bolts, gray, gt3, mounting, number, numbers, part, porsche, seats, space
