R Tires on Street Full-Time?
How about a better idea? Do what I'm going to do. Assuming you don't have a car trailer and don't plan to get one...Get another set of rims and put R-compounds on them (MSPCs, Dunlops, Corsas, etc.) and use these only for the track and getting there and back. Use the original set of rims with a good set of street tires like the Michelin PS2s. You'll get the best of both worlds. The one caveat will be what you do to the alignment as this will wear whichever set you have on the car more unevenly than the stock alignment. Other than the rims, you just need a good jack, maybe some jack stands and a torque wrench. Another option is a putting a trailer hitch on the car and towing a small trailer with all the above. I've seen a GT3 with this, but I myself can't get my mind around having a trailer hitch on a GT3...
fryd, that was exactly my plan, until I saw all the posts about how the MPSC transforms the GT3. It was probably clear that those posts referred to track behavior, but I did manage to confuse myself. I think it's pretty clear now. I plan to wear out my stock tires on the street and track with a street alignment and then, when I have enough track days scheduled spring for the second set of wheels with R-rated tires.
#1 - Never sell a Ducati
yep, sold my old Superlight, #758, it was severly tuned by ProItalia, and was one of the best machines I ever owned. Motorcyclist mag did a big story on it back in the day too. I really miss it!
I drive with my MPSC every day. I've been doing that for 3 years (Boxster and GT3).
They last as long as the Pirelli PZero street tires. I don't need to have a third set of wheels.
They're really bad on cold weather and rain.
The BMW M3 CSL comes from the factory with MPSC. The Ferrari 360CS comes with Pirelli PZero Corsa (R-compound).
If I get a third set of wheels for the track, I would rather run Yoko slicks than MPSC.
hey nj-gt. i think your the only one on the board who has the 265/315 combo tires on right now. i am looking to do the same for next season's track outings.
what camber are you running front and rear with it? ride height?
now that you have driven it for a while, do you find it rubbing and if so, are you going to roll the fenders (which is what my shop is suggesting)
Thanks, Gregg Healey
Wilton, CT
PS are you going to Watkins Glen this monday? if so, ill see you there
Wilton, CT
If you are going to do both street AND some track events, your suspension set up will be compromised. You'll either have too much negative camber for the street, or not enough for the track. Or a combination of both.
Because of this, you'll experience uneven tire wear. Either you will wear out the outside shoulder on the track prematurely, or the inside edge on the street.
Additionally, the heat cycles from the street will reduce the grip of the tires, especially on the track.
In short, you are going to trash tires very quickly.
This has led me to decide to run cheaper R compounds for dual use. As an example, the Kumho R compounds are nearly 1/2 the price of your typical MPSC, Hoosier etc. I haven't checked into the new dunlops yet.
