Emissions
Got an ageing sensor behind cat bank 2 and bank 1 P0136 and P0156 after just replacing all 4 O2s - anyone run into this? - I replaced all 4 because I wanted to start with new O2s since the car is new to me.
Yes oem installed correctly. I did do a dumb thing and read the bulletin too late in that I used connector cleaner- though the other sensors aren’t throwing a code
Do you know if the cats are still good? One easy test is to use an IR temp sensor. the cats should be a bit warmer that the surrounding pipes. Also your emissions should be fine. The cats can also start to break down and cause problems.
Ray
Ray
