Power Steering Leak
I have two minor leaks, one is with a hose and I believe it is the O-rings that are the actual issue.
The second one is at the power steering reservoir tank. There appears to be leaking at the seam between the cover and lower half of the tank. I am assuming it is a gasket. Does anyone know if a gasket is available for this metal tank or do I need a whole new tank?
I think a square "o" ring seals top to bottom.
I had mine off when I dropped the engine.
Easier to remove the top and keep the return line installed rather than risk damaging the return line to top seal.
