looking for a chain adjuster 95910505104
Hello All,
My mechanic is revising the engine and we are looking for at chain adjuster 95910505104.
Its nowhere to be found. any idea where we could source one?
Thank you in advance for your support.
kr
Barchstein
kr
Barchstein
I checked a couple Porsche dealerships in the United States, the part is in their catalog but neither one shows any in stock. You should ask them to see if the part is in a Porsche parts warehouse in the United States.
$437 (US Dollars)
$437 (US Dollars)
thanks for the tip. there is no stock at all for this P/N.
I keep on having 95910505101 that sounds like the part im looking for.
Anybody can point me to what the difference is between these? i feel like they are the same, just a different version...
thanks for any input to clarify these 2 p/n and if they are the same or not or compatible
(there is lots of stock of 95910505101)
Ray
We used the 997.2 Cup tensioners on my last Mezger build. These are the 997 part number ones and replaced the 959 part number which came out. Side by side comparison between the two, the Cup ones were stiffer.
The adjusters which were used in the last 997 cup engines with article numbers: 997.105.061.70 and 997.105.062.70
are available from the aftermarket here in germany.
Schaeffler / INA part number 551 0045 10 and 551 0043 10
just remember stiffer tensioners mean added wear on chains and ramps
