Brake Sound
Brake Sound
Hi all, my new (to me) GT3 is making a (brake related) sound, figured I’d post here before taking it to the shop.
Vid 1: This sound is most visible when turning the whee a few degrees either right or left, the car must be moving to head the sound. Speed doesn’t seem to matter (sound is visible at 60mph).
Vid 2: just noticed it today, loud droning sort of sound. Noise made under braking.
The car is on original PCCB rotors/(yellow) pads - roughly 45k miles on them. I think it’s either a rock stuck somewhere, or one of my pads are low. Looking from the outside the rotors/pads are in good shape, there is a very light sign of uneven wear on some of the rotors, will upload pics in a bit. Would appreciate any insight!
For video 1, I'm wondering if that is a suspension related noise and not a brake related noise.
For video 2, I'd want to take the wheel off and check the passenger side caliper, pads, rotors. You won't be able to see the inner pad with the wheel on, so that is why I mentioned to take the wheel off.
Yep, I would've taken it off, but I have absolutely no tools, LOL. Will be getting some shortly. Appreciate the help!
I'm fairly confident it must be some gravel/stone stuck in a crevice as the car makes a slightly sandy/grinding noise when I push it (car turned off/neutral/handbrake off). I think I'm going to use this as an excuse to buy some normal rotors, would hate to have a stone ruin a CC rotor.
I had a very similar squeak on my GT3 a couple of months ago, it turned out to be a calliper that was not properly torqued. Once I torqued up the calliper the sound disappeared.
engerman (12-28-2020)
Interesting, I assumed it's a brake related noise as the sound goes away as soon as I touch the brakes, but will check it out.
you'll know as soon as you get the wheel off?
No tools and you bought a 6 GT3??
I predict that will change!
Regarding the sounds, everything was solved after doing the swapping the rotors/bedding procedure. Did have one code brown on the way back home though, shortly after the bedding procedure a "(lamp image) Failure" popped up on the screen for a second and immediately went away. Pulled over and shut the car off, checked it out, started it and drove home without any problems. Definitely spiced up the evening!
