Engine Accessory Wiring photo request - Alternator area
I'll make is simple since I tended to go on / on below.
If you have photos of engine on stand or otheriwse out of car, please post.
I am interested in drivers side from the rear and the side.
Thank you
Yes, finally putting things back together and since it's been 6 weeks since I disassembled and I don't seem to have a photo of this area...........
I'm trying to route the cabling, factory correct, to the wire attachment point that is between the alternator and the AC compressor.
Not sure what that terminal is called, but it is 3 cable junction of ~ 4 gauge cables into a "resin" standoff.
Photos here of the cable junction that I'm trying to describe.
Ideally it would be a photo showing the attachment of the resin block to the hanger shown below.
The block fastens onto the two studs with the nuts installed.
something like this photo, but "up and to the left?".
Thank you
Found some useful photo's here
https://rennlist.com/forums/996-gt2-...-fittings.html
unfortunately some photos from Rbahr and Andy (Audion19s) are no longer hosted which is a photobucket issue
sad face here
sad face here
Sooooo, I got pictures (Really hope I have enough) - all the way to the the last nut & bolt. Let me know wheat you need, and I will try and find it, BUT I have several hundred...
Ray
Ray
