996 Forum 1999-2005
Bad Rear Differential - With Sound!
Old 07-10-2017 | 06:19 PM
sjg1138's Avatar
sjg1138
Default Bad Rear Differential - With Sound!
Hi all.
I'm getting a noise from my car which I at first thought might be a wheel bearing but has been since diagnosed by a Porsche Indy as a problem with the rear differential ('99 cabrio 6-speed manual).
Do you guys agree and if so, do you think I should send the entire gearboxto Gbox along with $3,500 or should I try to replace the differential myself?
The transmission has no other issues that I am aware of. it shifts great.
It seems that the differential can be replace in-suto without dropping the entire gear box. Anyone here have experience doing this?
https://drive.google.com/open?id=0B8...1phcTd5MUNhX2s
Above is a link to a recording of the sound the car makes. The sound (whomp-whomp-whomp) is independent of clutch position and varies with the speed of the car. its most noticeable when the engine is idling and the car is moving in neutral but i think this is because the engine noise just covers it up. The period of whomp-whomp sounds get longer and longer as i slow to a stop.
In the clip i am at first in neutral moving at say 10MPH until i slow to a stop. i then accelerate (engine noise) and then slow to a stop in neutral again (so you can hear the noise again).
TIA
Old 07-10-2017 | 06:34 PM
Chris(MA)'s Avatar
Chris(MA)
maybe buy this?
https://rennlist.com/forums/parts-ma...for-996-a.html
Old 07-10-2017 | 06:55 PM
ltusler's Avatar
ltusler
Have you drained the fluid and is it silver? Then it may be the pinion bearing.
Old 07-10-2017 | 06:58 PM
sjg1138's Avatar
sjg1138
Is the pinion bearing part of the Differential ? I'm not sure about the color of the fluid, the indy replaced it.
Old 07-10-2017 | 07:46 PM
sjg1138's Avatar
sjg1138
Fluid was not silver.
Old 12-22-2018 | 10:10 AM
turbogrill's Avatar
turbogrill
Any updates on this?
have the same sound. You dont hear unless you turn off radio and listen for it on a quiet road. Just appeared suddenly.
Old 12-24-2018 | 03:59 PM
Kebby33's Avatar
Kebby33
I too am curious if this was resolved. My newly acquired 02' C4S has a similar sound
Old 12-21-2022 | 01:33 PM
sjg1138's Avatar
sjg1138
After the fluid was changed, the sound eventually went away.
Old 12-21-2022 | 04:10 PM
EVOMMM's Avatar
EVOMMM
Change the fluid again to take out any residual mush
Old 12-21-2022 | 04:52 PM
dsbl's Avatar
dsbl
Yes good idea, then report back in 2026 and we can put this thread to bed
The following 2 users liked this post by dsbl:
Boff (12-21-2022), GC996 (12-21-2022)
Quick Reply: Bad Rear Differential - With Sound!
