PSM, ABS, P0102 lights after replacing regulator
4th Gear
I replaced the voltage regulator on my alternator last weekend. After I put everything back together and started the car I immediately got a error code indicating my PSM and ABS were not working. I drove the car around for a bit and then I got a check engine light. The check engine light code is P0102, MAF sensor low voltage. The car drives perfect. The voltage is reading 14 volts when running. I replaced the MAF sensor with a new one, cleared the code and nothing changed. Does anybody know what could be going on here?
PS: I do have a K&N air intake if that makes any difference. I had it on before I did the work and did not have any check engine lights, beside low voltage.
4th Gear
I believe it is plugged in correctly. I double checked the direction of the MAF based on pictures I found on the net and made sure the plug was clipped in firmly.
I had the same after replacing my alternator, and it was because I left the MAF disconnected at the end of the job.
After it was reconnected and the car restarted, the PSM / ABS warning lights went out as I pulled away from the curb. I've had no issues in the 3 months afterwards.
