996 Forum 1999-2005
236,000 Miles Between Them
Old 06-26-2017 | 06:04 PM
Kris Murphy's Avatar
Kris Murphy
Default 236,000 Miles Between Them
While towing to the track this weekend the Douche Canoe (Cayenne) hit 118K miles. The 996 also has 118K miles.
Now I'm just going to drive each one 10 miles at a time some they always have the same mileage.
Of course the track car rewarded me with a blown AOS (which only has 1600 miles on it) and continued low oil pressure in the turns after 10 minutes of driving.
Old 06-26-2017 | 08:51 PM
Ahmet's Avatar
Ahmet
1600 miles to an AOS doesn't sound good, what do you think is causing that. Also, congrats!
Old 06-26-2017 | 11:53 PM
Woodman71's Avatar
Woodman71
You should tow the 911 100 miles, then switch and tow the Cayenne with the 911 for 100 more.
Old 06-27-2017 | 02:30 AM
MoeMonney's Avatar
MoeMonney
You should polish those headlights on the cayenne.
Old 06-27-2017 | 10:52 AM
Kris Murphy
I think driving it on the track is what the AOS does not like. Lots of the cars at the track have a puff of smoke at start-up. Most of them just keep going.
Since I'm still gun shy from blowing the motor in October, I'm not willing to take the chance of continuing to track it with a bad AOS.
Old 06-27-2017 | 10:53 AM
Kris Murphy
Sadly, I have done it twice. I think they are too far gone.
Old 06-27-2017 | 11:24 AM
RickMiller's Avatar
RickMiller
Makes me and my sissy 50,000 miles seem quaint
R
Old 06-27-2017 | 08:15 PM
Ahmet's Avatar
Ahmet
I've done lots of track events in many different 996 Carreras. Some had puff of smoke, some didn't. I wouldn't conclude that's the AOS off hand, though please do keep us updated as to what's going on!
Old 06-27-2017 | 08:43 PM
fpb111's Avatar
fpb111
If you fill oil to the top bar the AOS has to work extra hard on the track. Maybe try running it ~2 bars low to give the AOS a bit of a break?
Old 06-28-2017 | 11:39 AM
Kris Murphy
It wasn't just a puff on smoke, it was a puff of smoke that did not clear up for 5 minutes (more throttle increased the smoke) it did eventually clear up.
I pulled the throttle body and plenum, and there was a good amount of oil there. So I am fairly confident it is the AOS.
Old 06-28-2017 | 11:41 AM
Kris Murphy
At the max, it was 2 bars below full. I started the day between the low mark and middle. Or are you saying I should run it 2 bars below the low mark?
Old 06-28-2017 | 11:48 AM
AWDGuy's Avatar
AWDGuy
my car hasn't smoked 1 bit the last 2 track days I've done. 1st track day I ran the oIL at the half way mark. 2nd track day I ran it 2 bars down from the top.
5 minutes of continued smoke is excessive and I would suspect a bad aos....even when I had scored cylinders the car would stop smoking after 20 seconds or so.
Quick Reply: 236,000 Miles Between Them
