996 Forum 1999-2005
Door not locking
Old Jun 25, 2017 | 09:13 PM
dmilzoff's Avatar
dmilzoff
Default Door not locking
The doors on my 2003 996TT are not locking with the key. (Both key fobs have not worked for years.)
The alarm does set. I do not hear the 'click' when I turn the key to lock the door.
I believe that it is the driver's door lock itself.
Any opinions? Any help with parts and directions to repair is appreciated.
I would like to do the repairs myself.
David
Old Jun 26, 2017 | 09:51 AM
DBJoe996's Avatar
DBJoe996
There is a shaft on the inside part of the lock cylinder that has been known to come loose or slide out of position. Follow directions for removing the door card (like for replacing the window regulator) so you can get at the inside part of the door handle/lock cylinder. See parts here http://www.autoatlanta.com/porsche-p...section=804-20
Old Jun 26, 2017 | 10:17 AM
dmilzoff's Avatar
dmilzoff
Thanx.
I will follow disassembly directions. It may just be a movement of the shaft.
