Never ends....now the switches in my door
The other day, my toddler busted out her plastic tools and started wrenching on her cozy coupe because her car wasn't feeling well. Gee, I wonder where she got that from.
And I got the codes scanned for the airbag, Passenger seat belt and power supply.
Replace seat belt buckle?
Also had 6 codes for security system, might be why my Duramteric wont connect to the car. But then again.....why would every other type of scanner work? I dotn really give a **** about the security codes, they dont produce idiot lights. lol
Rocky Mountain High
I understand how you feel with the constant repairs. This is the reason that I sold my 996; the repair bills kept getting bigger and more frequent.
So, are you saying that the noise in the video is like yours? Or, is that actually your car? The strange thing is that you originally said your car made the noise when going from forward or neutral to reverse. The video shows the axle being pulled away from the transmission...
that's my car on the hoist. And yes it still makes that noise going forward to reverse.
Oops! Sorry about that...I think I can chalk it up to this "updated" format where one thread scrolls right into another "related thread"...
Currently:
* The ABS/PSM light is firing again, intermittently, due to...
* Third taillight needs replacing (currently, just a cut wire back there)
* My cluster tries to catch fire if I use the headlights
* I screwed up one of the LCD polarizing filters when I was dicking with the cluster.
* Still missing a side marker.
* Judging by the god-awful alternator whine, it's probably time for a new alternator or voltage regulator
* One of the mufflers is coming apart internally and occasionally rattles like a ****.
* Driver-side window regulator cable needs to be replaced (or repaired).
* I pushed the sunroof switch partially up into the console.
And - dammit - I still can't stomach the idea of getting rid of this car.
Airbag light came on and figure maybe it cold have been a connector or something from when I replaced the window regulator so i opened up the passenger door.
something that was going to take 2 minutes has turned into a complete nightmare.
the two connectors that go into the door handle broke off. while trying to fish the connectors out it was quite apparent someone was in here.
the connector broke in half and as you can see someone tried gluing it or something. anyone know where I can find these connectors?
Attachment 1191365
Attachment 1191366
Attachment 1191365
Attachment 1191366
http://connectorexperts.com/c-126162...-cavities.html
