radio will not take code
title pretty much covers it,
i had to change the battery and now my radio is locked. i tried several different codes but none will work, is it wrong code or fried radio? how can i find out?
the nearest dealer is a 5 hour drive, it would be cheaper to buy a new stereo.
Received 1,198 Likes
Try here - https://www.renntech.org/forums/topi...ad-this-first/
If that doesn't help try the link to post your request
Have you in the past used that code successfully on that radio? If not, then it's probably the wrong code. Visit the link on renntech and you should be able to get the right code, it worked for me.
