Oil change and dash gauge not functioning properly
Changed the oil last week with
a full 2+ hour drain
After consolidating all the oil, it measured 8 1/2 qts.
Perfectly clean drain plug and I drained and stored the filter
a Wix because I have the L & N spin on adapter
So after 8 full quarts, let the car idle to warm up and a few
hours later add another 1/2 qt. and another pint or so the next
day
The oil level sensor shows 3 bars when actuated, but the dipstick
reads dead center
Car runs perfectly, no smoke, no overfill
Pressure gauge operates as it did previously
I trust the dipstick and have been driving the car almost daily
anyone ever have this happen ? did it return to functioning normally ?
I read this and suppose the Oil Level Sensor could have gone bad as depicted here
https://rennlist.com/forums/996-foru...-replaced.html
day
reads dead center
Received 1,091 Likes
I do not understand but it seems about right with only 8.5 quarts that you would only get 3 bars. That's a bit low for normal DD. You said your dipstick reads dead center which means you are below the full mark. I don't get why you would run that level. Get the engine stone cold, like after sitting overnight, check engine oil level and bring it up to the full mark. Mine takes 10.25 quarts after an oil/oil filter change to hit the full mark, stock oil pan and spin-on adapter. Then, when it is run the oil level drops a little due to circulation of the oil in the engine.
now the dash gauge reads properly
I'd forgotten that previous changes were in excess of 9 qts.
smh
