Earliest production dates
- double row IMS
- better alu casting for engine
- more balanced cooling water flow through the engine (compared to mk2 3.6L engines)
- throttle cable (C2 only) iso e-gas
- no ***** glove box! No cup holders!
- still can open frunk / boot with flat battery
Other?
Volkert
What I understood on why early 996 are the ones to have:
- double row IMS
Other?
Volkert
- double row IMS
Other?
Volkert
/s
Did your car have a Brumos sticker in the windshield that said the car had been "test driven & approved by" with Hurley Haywood's signature on it?
My former '00 (may 2000 build code) came from Brumos as well and had such a sticker on it... Wondering if that was a normal occurrence back then?
There was a very low optioned '99 coupe for sale near me for the longest time with a 2/98 build date and 133k miles on the odo. Almost bought that car twice, but couldn't overcome the "arrest me" Guards Red color on the car. The only red I would consider is Arena Red. The 2000 Millennium Edition car I bought instead has Oct '99 build date and 40k less miles. Pretty happy the way things worked out.
Also, why does this matter? A Boxster was still a Porsche last time I checked. Guess what? The engine is also a Boxster engine with a slightly larger bore size, they even use the same heads, and camshafts.
So my coupe is a 10/98 build MY99 Carrera 4 (delivered 2/99).
The cab is a bit more interesting - I don't have the production month on hand, but it was MY00 and delivered 12/99, so I assume it was relatively early (or maybe not; in any case I feel relatively confident that it was built prior to the date of delivery in calendar year 1999). It's got a cable pull for frunk/engine compartment, but it's also got the frunk release button on the keys (the button does nothing). Just a weird quirk.
