Goofy Problem
Goofy Problem
For the record, I searched several sites and found plenty of similar issues, but not this one - which is a little weird. A couple of weeks ago, my ABS and PSM off lightss came on during hard acceleration onto a freeway on ramp. There were no codes and when I turned the vehicle off and back on the lights reset. With a bit of experimentation, I have found that I can get them to come on under hard acceleration (over 5.5k rpm - typically in 2nd gear) pretty much every time. So far, no codes and the lights always reset.
The only thing I've changed were recently some new wheels and tires, otherwise everything is the same. Any ideas?
As an aside, I have a spare MAF that I bought during a troubleshooting session over a year ago. I may swap it in to see what happens, but the car otherwise seems to be running fine.
R
R
Long story short, I finally swapped out my MAF and it looks like that did the trick. In the last couple of weeks, I could trigger the lights pretty much at will in any gear as long I got to 5k rpm. Although I never really detected any power loss, a nice side benefit has been a smoother running engine - can't wait to take it for an extended run this weekend!
I had same problem and after many searches found a mention of this being the problem. MAF threw all sorts of weird codes abs, O2 heater. None since I changed it out years ago.
Range Master
Pepsie Lite
Pepsie Lite
Yup, MAF. had the exact issue, did throw codes though.........
