996 Forum 1999-2005
How to change outside temperature?
Old 03-15-2017, 12:30 PM
Dans996tt
Dans996tt's Avatar
Originally Posted by m3driver
I added the 4th stalk without removing the wheel. A durametric will not work on a 99 for activating the on board computer. On the 99's the durametric all but sucks. You can read basic codes with it, but other than that it's garbage. Durametric will attempt to tell you there is a problem with your car, when in fact the problem is with their unit.
I was able to turn on the temp on my 99 Boxster with the Durametric so a 996 should work also.
Dan
Old 03-15-2017, 05:04 PM
m3driver
m3driver's Avatar
Dan
Should is the key word...it is well documented on this site the durametric is junk on a 99. I personally went through 3 different professional cables only to have durametric say there was a problem with my car. I took it to the dealer and was out in five mins, no issues what so ever
Old 03-16-2017, 05:31 PM
Mike Murphy
Mike Murphy's Avatar
Received 1,638 Likes on 1,020 Posts
Originally Posted by longrowe
The OBC can be enabled with Durametric. There is a toggle for it I believe in the cluster section. But for those '99 people with no OBC stalk, all you get is the outside temperature. Mine reads in Celcius since I am not in the US. I will need to hook up my system to see if there was a way to change the display type.
If that's the case, then i'll use the Audi-based HVAC display cheat where I can already view the outside temperature in Celcius. But I still plan to get a durametric for other reasons. Which reminds me, I would love to find a used one if anyone has one for sale.
Old 03-17-2017, 06:57 PM
babylonboots
babylonboots's Avatar
I just do the math... °C *9/5 +32
Quick Reply: How to change outside temperature?
