How-To : Re-Pin Porsche 996 headlight connector
Hi Everyone,
I'm doing the 996 to 997 GT3-RS front conversion and need to re-pin the headlight connector as the 997 use A5 Pin instead of A4 as the 996 (for the High Beam)
My question is how can I remove the pin from A4 and put it back in A5 ?
How to re-pin the headlight connector ?
I did a lot of search and didn't find anything specific on Porsche 996.
Alex
Alex
You need a "molex" pin tool. Something like this:
https://www.amazon.com/mod-smart-Ful.../dp/B001KQDS6G
Anything small enough to get in and bend the wings out of the way should do though really. I use dental/modeling picks.
Look at the connector really well though as there could be some other mechanism helping to hold the pins in.
For example on the connecters I had to use for my P!g's bumper conversion, in addition to the wings on the pins themselves there was a little slide lock buried at the base. I wouldn't have even known it was there if I hadn't been building an adapter (it came with the slide in the open position) rather than messing with the wiring harness directly.
you may nfind something on this link to several pin removals videos.
https://www.youtube.com/results?sear...rom+connector+
