It's snowing foam
very common issues in these cars.
i fixed it on my first Boxster when i replaced a leaking AC evaporator.
i took a lot of pictures just so i can put everything back in place.
the following weekend we had a tropical storm, so i staid at home, and created tease DIY guilds. i broke the project into three sections, so they can be used separately. if you only wish to clean it up, step 1 is enough.
ArGian (01-12-2022)
just in case someone is interested in part 2 and 3
from some reason i cannot upload another file to the previous post.
i guess the files are too large, so here is a link to my dropbox (i think you must have dropbox in order to download it)
Dash removal
https://www.dropbox.com/s/lcthesknyn...moval.pdf?dl=0
Evaporator replacement
https://www.dropbox.com/s/gja11v6yi6...ement.pdf?dl=0
Dash removal
ArGian (01-12-2022)
Nice write up.
Many thanks for the feedback.
To be on the safe side I will have the car flat bedded to my indy where I will instruct him to immediately change the IMS, AOS and RMS again and then begin to diagnose the problem...
The car lived in St Petersburg, FL before migrating to Houston a couple of years ago so the comment about heat and humidity make sense.
I will just deal with the black snow for now as the heater use is very infrequent.
