996 Forum 1999-2005
Sagging Springs?
Old 11-07-2016 | 04:30 AM
Jas hunter's Avatar
Jas hunter
Default Sagging Springs?
I have H&R sport springs (29513) fitted to my new (to me) '03 Targa. Rear is decidedly low compared to the front!
Roughly 25mm gap between wheel arch and tyre at the fronts but the wheel arch at the rear is probably 25mm below! definitely not a matching gap and looking a little too gangsta.
Can only presume the springs (or just H&R springs) sag a lot over time? though as they were installed by a PO i have no idea how long they've been on the car.
Anyone seen this before?
need to get the height back up to something sensible but not stock. HR is off the shopping list though.
Jas
Old 11-07-2016 | 04:33 AM
Jas hunter's Avatar
Jas hunter
duplicate image deleted
Old 11-07-2016 | 04:51 AM
Stephen Tinker's Avatar
Stephen Tinker
I wouldn't have thought that a reputable company like H&R would have coil spring that would sag so much - is the ride height the same both sides? I've heard of standard springs snapping but not aftermarket premium springs.....
Do you have standard shocks fitted to the H&R springs or could they be (if you are lucky) adjustable coilovers, in which case you can higher the ride height.
Old 11-07-2016 | 04:57 AM
Jas hunter's Avatar
Jas hunter
It's unusual indeed. Looks like it's the same on both sides, nothing seems cracked. and the springs are on what looks like stock struts
jas
Old 11-07-2016 | 02:12 PM
OKB's Avatar
OKB
check h and r site and make sure they are the right ones. make sure they arent some special performance version. some people think they can put any spring on any car
Old 11-07-2016 | 03:13 PM
Jas hunter's Avatar
Jas hunter
Does seem to be the correct spring for the car
j
Old 11-07-2016 | 03:46 PM
TAGPorsche's Avatar
TAGPorsche
Maybe the PO went a little ghetto and cut the spring at the top to go more flush?
Old 11-07-2016 | 04:07 PM
rymerc's Avatar
rymerc
Not uncommon for H&R rear springs. I remember a thread where someone modded a hockey puck to level theirs
http://www.6speedonline.com/forums/9...-rear-end.html
There it is!
Old 11-08-2016 | 01:13 AM
Jas hunter's Avatar
Jas hunter
Ah yes thanks. Just read this.
Seems Im not alone in the sagging department
j
Old 11-08-2016 | 07:27 PM
OKB's Avatar
OKB
assume your springs may be 13 yrs old too
Old 11-09-2016 | 10:14 AM
ditto's Avatar
ditto
Targas are heavier than straight coupes, especially in the back. If the spring selection did not consider that it could be part of the problem.
Old 11-10-2016 | 11:13 AM
dporto's Avatar
dporto
There are two different sets of H&R sport springs for Targa/Cabrio...
C2 = 29513-2
C4 = 29466-2
Perhaps this is the problem?
Quick Reply: Sagging Springs?
