996 Forum 1999-2005
996 fixed wing weatherstrip question
Old 10-25-2016, 10:26 PM
RSQ911
RSQ911's Avatar
Default 996 fixed wing weatherstrip question
Greetings all-
What does everyone do for the rear weatherstrip "seal" that goes at the bottom of the engine cover where it meets the bumper?
The factory part #996.512.611.00, has protrusions that fit into the decklid, but most of the aftermarket ones don't have slots/receivers.
Do you modify the factory seal, go aftermarket, or go without?
Thanks,
Paul
Old 10-25-2016, 10:46 PM
dan_189
dan_189's Avatar
There is a specific AeroKit 2/GT3 weather strip without slots. It has a strip of tape to hold it in place.
IIRC it cost me $70AUD
You could get a used one and modify/cut the bits that hold it in place off and use tape. I just bought the GT3 OEM one.
I have a pic of it I can post later
Old 10-25-2016, 10:50 PM
RSQ911
RSQ911's Avatar
Excellent! Thanks for the info
Old 10-25-2016, 10:58 PM
dan_189
dan_189's Avatar
Just for your reference all the parts for an AeroKit 2 wing are from the GT3 MK2:
- Wing bolt covers
- Wing bolts
- Fan bolts
- Weather strip
- Wiring harness
- Snorkel is the same as any Carrera
- Angling wedges
If you're missing a part for the genuine AeroKit 2, look up the 996 GT3 on AutoAtlanta all the parts are on the rear lid diagram.
Additional info:
- The brackets for the blade cannot be bought as separate parts so dont damage or lose them (which is hard as they are riveted on)
- The underside of an AeroKit 2 decklid should be painted and finished with a gloss clear coat
Old 10-26-2016, 09:37 AM
dan_189
dan_189's Avatar
Quick Reply: 996 fixed wing weatherstrip question
