Anyone with a 996 / 997 3.6 and Durametric?
5th Gear
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
Hi
I've a Boxster with a 996 3.6 engine transplant.
I'd really love a Datalog from someone who has Durametric for warm up and a couple of steady power runs from the car so I can do a base map in an aftermarket Ecu.
I'm after settings such as Throttle Angle, Rpm, Ignition Timing, Inj Time, Cam Advance, Water Temp etc...
Can anyone help?
Marcus
Can anyone help?
Marcus
5th Gear
Well I my first request would be initially if I could 'borrow' the datalog file?
Maybe it would also be of technical interest to other people as how the DME / Engine Management Unit responds to various engine conditions?
I'm in Cirencester in the United Kingdom.
5th Gear
That would be great if you could. Ideally a log with as much of the following as possible
Rpm, Throttle plate angle, Ignition timing, Injection time, Cam advance, water temp, ...then any other data...lambda or other cam stats
Thank you :-)
Thank you :-)
