996 Forum 1999-2005
In need of a torque value to apply.
Old 09-28-2016 | 05:59 PM
Device2's Avatar
Device2
Default In need of a torque value to apply.
I've been having trouble finding the torque value for bolt #7 which is one of two that holds one half of the 996 motor to the crankcase piston rod and bearings assembly. Does anyone in the RL wealth of technical knowledge know the torque specified in the maintenance manual? Your assistance is greatly appreciated.
Old 09-28-2016 | 06:20 PM
gnat's Avatar
gnat
You should pic up a copy of "Fastening Specifications, Porsche 911 (996) Automobile" from The Knowledge Gruppe.
According to page 15 it is the "Crankcase to bearing housing" bolt and requires 22nm (16 ft-lb).
Edit: Woohoo!! I got to use the book and be helpful for a change!
Old 09-28-2016 | 06:47 PM
Device2's Avatar
Device2
gnat, thank you and much obliged for your assistance. I will definitely place the said titled book in my Xmas list as another must have for the Garage.
Old 09-28-2016 | 07:27 PM
OKB's Avatar
OKB
normally if you cant find a torque spec, you use the spec for the bolt size. find anywhere in torque spec for ( 8MM bolt ) example
Old 09-28-2016 | 11:34 PM
Byprodriver's Avatar
Byprodriver
Be sure head bolts are torqued 1st before torquing that bolt.
Quick Reply: In need of a torque value to apply.
