Ignition switch
You may want to open up the rear relay panel under the left rear seat to access the starter relay amd do some troubleshooting there. Basically verify of there is actually power to the starter solenoid at all whem you try to crank. If therr is and the starter is not spinning, then it's most likely the starter solenoid.
