996 Forum 1999-2005
Ignition switch replacement tip.
Old 09-06-2016, 05:30 PM
jgm911t
jgm911t's Avatar
Switch is installed, all works great!!! Thanks to all for the help
Old 09-22-2016, 10:12 AM
Oil_Slickrick
Oil_Slickrick's Avatar
Originally Posted by Schnell Gelb
Here you go ???
https://www.amazon.com/dp/B00A9NH91Q...buying_options
This is important because we often have weird electrical questions on the Forum and the prime suspect is the flimsy switch. But replacing it is such a chore that people re reluctant to do it.Instead they fiddle with other more accessible potential culprits and we go round and round. Eventually the switch gets replaced and the thread is abandoned. Guess why ...
Was this the right thread / part to use to adapt. I really like this idea? Thanks
Old 09-22-2016, 12:03 PM
lingpoen
lingpoen's Avatar
...u mean, I have to do this again?
Old 09-24-2016, 10:24 PM
Schnell Gelb
Schnell Gelb's Avatar
JTT bever confirmed the thread spec. Hopefully he or others will confirm for us.Anyone with an old ignition switch and a thread gauge would be a hero !
Old 09-25-2016, 06:30 AM
JTT
JTT's Avatar
Yeah, sorry about being so slow. I don't have a tap or thread gauge that small, so have to remember to bring it to a friend who is a machinist, with the proper tools to confirm.
Old 09-25-2016, 01:04 PM
Schnell Gelb
JTT - take your time - that is a morsel of information that any conscientious ,long-term diy oriented owner will be happy to wait for -because with the ignition switch -doing it once is never enough !
Old 09-25-2016, 04:08 PM
Aflick
4th Gear
Aflick's Avatar
I am in the middle of replacing my ignition switch with the NAPA ignition switch and have run into an issue. The connection is 90 degrees off from what I removed. Any tips on how to fix this?
Old 09-25-2016, 05:16 PM
FRUNKenstein
FRUNKenstein's Avatar
Aflick - Post up a couple of pictures so we can see what you are looking at.
Old 09-26-2016, 05:32 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Take it back and ask for another one.
Old 09-27-2016, 03:19 PM
5CHN3LL
5CHN3LL's Avatar
Yup - wrong part. The new one should be identical in appearance to the old one.
Old 10-03-2016, 06:21 AM
JTT
JTT's Avatar
Sorry for the delay lads, those set screws are M4 x .7. They do have a pointed end, so if you may want to grind a point to whatever screw you use.
Old 10-03-2016, 07:09 AM
Oil_Slickrick
Thanks for the update
Old 10-03-2016, 08:43 AM
DBJoe996
DBJoe996's Avatar
Received 1,165 Likes on 745 Posts
I wonder if something like these would facilitate the job of ignition switch replacement? M4 x .7 SS set screws w/knurled **** - http://www.scopestuff.com/ss_scr1.htm
Old 10-03-2016, 12:06 PM
Schnell Gelb
Perhaps, but we need to know the length of the threaded portion. If this is unknown, an assortment shown for the 'scopes in the ink above my be better. When we learn what the correct minimum length is, we can order the correct, specific fastener.
? these are 10mm long for example.
http://www.microfasteners.com/scms40...ess-steel.html
Old 10-03-2016, 08:30 PM
JTT
JTT's Avatar
Sorry, my bad. I'm guessing around 8mm of thread. I believe the screw I used was around 20mm. Those knurled top ones would be perfect!
Quick Reply: Ignition switch replacement tip.
