Oil Pump Upgrade
#46
Yes.And welcome to geekdom Mr. Radium!
In a normal engine there are plenty of drain holes to replenish oil in the sump.In this configuration we rely on those two English scavenge pumps. If they can't "keep up" as the Brits would say, the accumulating oil in the heads will cause oil smoke in the exhaust and maybe dangerously low oil level in the sump ?
Solution - a partial at least may be to have a deep sump and reduce revs when you see oil smoke ?
#47
Qumulus had a few recent posts on an aftermarket dry sump system his buddy was developing . I'll try to find and repost it. Basically his buddy had tested various deep sump systems and Accusump for Track and found them all wanting. After destroying several engines trying to develop a better system ,he found the answer. And all will be revealed bu Mr. Q. soon -I hope.
Here it is:
https://rennlist.com/forums/racing-a...mp-system.html
Here it is:
#49
I read on Renntech that there is an upgraded oil pump piston and spring that is a useful upgrade to increase low RPM oil pressure. The piston is beveled to solve a sticking issue (?) and the spring is slightly longer.
Has anyone done this upgrade or have an opinion about it? Does it apply to all 996 models or do later ones already have either the newer spring or the piston?
The bolt on mine was really cinched on there, but once loose it was easy to undo it. I just used a fat finger to plug it while I checked out the differences between the old & new. After a drive around town to get gas & drop off some old oil, the oil pressure was reading a bit over 1bar at idle. The swap only required a refill of around half a quart, not as bad as I expected.
17mm wrench did the trick, had to use my pinky and eventually a small scredriver without a bit on the end to get the piston to work past the rivest for the bolt.
Once out it was easy to plug it & compare & contrast. New spring a few mm longer than the old one. New piston clearly shows the bevel on the edge. All looking good according to prior advice.
new piston on top, old on bottom
old spring on top, new on bottom
new unit prepared for installation
As always, thanks to the contributors of the thread for making this low stress & easy to replicate!
MoveableBeast (07-02-2021)
