996 Forum 1999-2005
Try and smack this tophat bolt out or not?
Old 08-08-2016, 08:47 PM
  #31
jj1
jj1's Avatar
Hammer and plumb bob or pick or whatever. Only thing you'll damage is the top hat that's already damaged.
Old 08-08-2016, 09:13 PM
  #32
5CHN3LL
5CHN3LL's Avatar
Just randomly picking pointy tools for the job?
Old 08-08-2016, 11:06 PM
  #33
Byprodriver
Byprodriver's Avatar
Originally Posted by Cuda911
I'm going to eventually upgrade the suspension, but can't do that until the end of the season, as it will move me to a different car classification category. That's why I want a band-aid solution for now, if it will work.
Youri, I don't think there's any way to get vice grips, etc. on it from the bottom.
That is correct.
I have one I can experiment with, or if you happen to be in Costa Mesa this week you can have it.
Old 08-08-2016, 11:23 PM
  #34
Dan951Man
Dan951Man's Avatar
I'm with Prodriver- I have one I can destroy for science or you can have it if you are in the San Francisco area.
It is a bolt with a splined bottom as previously mentioned. Air hammer would be the best bet at avoiding collateral damage.
Most people crank down on these way too tight. If they did one you can bet the rest were not treated any better. It sounds like you know the tops should be changed end of season, but if you successfully knock one out easy piesy- my suggestion is replace the others while you are there? At least on that side....then again if you taught Macgyver how to Macgyver maybe it's best not to poke the bear.
Old 08-08-2016, 11:41 PM
  #35
Cuda911
Cuda911's Avatar
Thanks, guys. Byprodriver, sure, if you have a few spare moment and want to experiment with it, that would be great. Dan951man, is it a new part you have? This is on a '99 boxter, stock suspension. Here's the part I need.
If it's the right part and you want to sell it, let me know. That way, after I screw this up, I will have the part on hand.
Hmmm... it has a 997 part number? Will that **** off the 997 guys to know that they are sharing parts with a Boxster?
Old 08-08-2016, 11:55 PM
  #36
Byprodriver
Well your luck is getin' beta & beta! My team is losing & I can't watch anymore, it's hammer time!
Took a pretty good rap to dislodge it but if you hit it straight it's outa there.
The larger diameter base is splined the width of the mounting plate that holds the bushing, apox 1.5mm. Then the threaded part is about 16mm long & 8mmx 1 threads. "Bolt" is 10.9 grade. So you won't find a suitable bolt to substitute for it. Pm me your address & I'll mail you a couple & you can line up the splines by feel & pull it into place with a nut.
This is the front correct ?
Old 08-09-2016, 12:03 AM
  #37
Cuda911
Cuda911's Avatar
Nice experimenting there!
You have those bolts? Curious, why? Hey, that would be great! Also need the nut. $0.78 part, but they want $6.50 shipping @#!&. PM sent.
Old 08-09-2016, 12:22 PM
  #38
alpine003
alpine003's Avatar
I have a manual impact screwdriver, so maybe that will work.
LOL, uh.... no...
Old 08-09-2016, 12:23 PM
  #39
5CHN3LL
5CHN3LL's Avatar
Yes, you could also light a fire on it and hit it with a brontosaurus femur.
Cretin.
Old 08-09-2016, 09:33 PM
  #40
Cuda911
Cuda911's Avatar
Originally Posted by alpine003
LOL, uh.... no...
Actually, I just plan to use a metal punch and a hammer. I'll drill a bit more of a divot into it to help center the punch. Not enough of the bolt sticking up to hit it directly with a hammer.
Byprodriver is mailing me a bolt. I'll update the thread when I get a chance to break something else.
Old 08-10-2016, 12:19 PM
  #41
DTMiller
DTMiller's Avatar
Update?
Old 08-10-2016, 01:07 PM
  #42
sweet victory
sweet victory's Avatar
If you're hesitate to apply heat, using an upside down keyboard cleaner could work. Same principle, but opposite thing. - Engineering Explained
Old 08-10-2016, 01:53 PM
  #43
Cuda911
Cuda911's Avatar
Originally Posted by DTMiller
Update?
Waiting for the bolt to arrive. Should be here any day now.
Old 08-10-2016, 02:42 PM
  #44
DTMiller
DTMiller's Avatar
Which day?
Old 08-10-2016, 03:02 PM
  #45
alpine003
alpine003's Avatar
Give us the tracking number so we can monitor your progress or lack of...
Quick Reply: Try and smack this tophat bolt out or not?
