996 Forum 1999-2005
Broken muffler PSE
Old Jun 16, 2016 | 07:42 PM
Anders451's Avatar
Anders451
Default Broken muffler PSE
Hi,
New to this forum, glad to see so many enthusiasts around
I'm having an issue with my 43k mile 996 Carrera 2002 that suddenly started to sound akward. It has factoryfitted PSE, the XLF-option. I took it to a specialist who said that one muffler was broken (had a crack inside of it).
When I asked for cost for replacement he said (after research) that you couldn't get your hands on a single PSE muffler but had to replace the entire system for a whopping 4k USD.
My question is if anyone has experienced the same issue? Has anyone successfully welded a cracked muffler or managed to find a replacement?
My mechanic has been very nice and asked if I want to replace to something non-original but I really want to keep my 996 as factoryfitted as I can.
Thankful for any help I can get. Sorry for lousy english, Im from Sweden.
Regards,
Old Jun 16, 2016 | 08:00 PM
mrhebert's Avatar
mrhebert
Those mufflers have bad baffles. If it's rattling when you blip the throttle, it's bad baffles. My advise is to go to aftermarket. it will sound better and be less costly. The value of your car will not change one iota.
Old Jun 16, 2016 | 09:29 PM
Triple Black's Avatar
Triple Black
Pick up a used non-PSE muffler on ebay - lots of them around (about $200). Then get a good muffler shop to cut off the bypass pipe with the PSE valve off of your existing muffler and weld it onto the "new" one. I had the same issue a couple of years ago. A lot less than the cost of an aftermarket system.
Old Jun 17, 2016 | 12:13 PM
alpine003's Avatar
alpine003
Or you can always cut part of the muffler case and have the baffles rewelded. This is commonly done, especially in Europe. Here's a sample pic of where to cut.
Old Jun 19, 2016 | 12:31 AM
nemo9xx's Avatar
nemo9xx
Have the same issue with both muffler, I cut both muffler and bright it to a soldering shop. Fix both with steinless steel soldering for 160$. Put back and no more problem. It is not a easy job to sold the muffler because the outside are in SS but the inside are steel. But I highly recommend to fix it it's a cheap fix and PSE always sound better in my opinion
Old Jul 22, 2016 | 05:10 PM
pierre_l's Avatar
pierre_l
Dear all,
I am suffering from the same issue.
anyone has experience doing this in Europe and could recommend me someone who could do the operation?
best,
pierre
Old Jul 22, 2016 | 05:56 PM
alpine003's Avatar
alpine003
Originally Posted by pierre_l
Dear all,
best,
pierre
I don't know exactly where you are but at least shipping won't be expensive if shipping on the same continent via DHL or something like that.
http://www.carnewal.com/
or find someone local that's good at working with metal and welding. That would be the best bet.
